Reset settings
Hello [2] Select your Location with the cursor up/down and press the green color button. If you choose Shop it will skip the Settings assistant. The TV parameters for Picture and Sound will then be set to predefined fixed settings. Press the green color button again to proceed. [4] Press the green color button to each time confirm your selection and to jump to the following screen. The following items will be presented sequentially. In the header it is mentioned how many screens have been completed and how many [5] Press the green color button once to store all the settings and to return to the TV installation menu. Note: When you skip or stop the Settings Assistant, then the Standard settings
[1] Press the green color button on your remote control to enter the Settings assistant menu.
If you choose Home it will display the Settings assistant.
[3] Use the cursor left/right to each time select your preferred screen.
screens there are in total. The Settings assistant will step sequentially through the following settings: Picture and Sound.
Philips selected for you will be chosen.
[6] Press the red color button to finish the First time installation procedure and to display the first stored TV channel.
OK.
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
