Hi mpk2210.
The FINE Cartridge Holder moves to the replacement position.
If you want to change the cartridges have a look at the on line guide and go to page 117:
Pixma MX340 Manual
There is a step by step guide including pictures to help you through it.
I hope this helps
Myke
Thanks for coming back to me MPK, Sorry I misunderstood your original request.
It sounds like your being asked to unplug the printer from the power supply, so switch it off at the wall.. The problem I can see with this is that the printhead wont move very easily with the power off..
If you lift the scanning unit and the print head does move to the centre with the power on, you could switch the power off at that stage.
Unfortunately like you I can't seen to find any information about the little grey bar either..
That does seem to be the only reference to fixing this error though..
Sorry I couldn't help any further.
Myke
the cartridges will center automatically with power on. once they do, THEN unplug the power, remove the ink cartridges, close things up and turn it on. it will give you a message to pull cartridges in so you open it and put them back in.
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can't remember exactly what it said but it was something like that).
8. Open printer, lift the gray arm that surrounds the ink cartridge area and reinsert the ink cartridge holder (with the ink cartridges in it). Lower the gray arm.
9. Close printer cover.
10. The display should appear normal now, and you should be able to print again.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Hello Mykel_N
Am having the error 5200 and the solution I found is:
* With the printer turned on,unplug it
* Open the top and bring the ink cartridge holder to the middle
* Raise the gray bar and remove the print head assembly with the cartridges in it
* Lower the gray bar with the head missing and close the top with the head out
* Restore the power,wait till the printer starts
* It will tell you to put in the cartridges
* Restore the print head, close the top and the printer should resume working
but I dont understand what exactly I have to "unplug" and the location of the "Gray Bar"...
