Siemens SpeedStream Modem (4100) (SS4100) Logo
Posted on Jul 27, 2008
Gigaset se568 siemens wireless Security setting
  • 9 more comments
  • mtk2002 Jul 27, 2008
    fdfdhj
  • Anonymous Aug 07, 2008
    i want to put wireless security password
  • ihab_saad Aug 27, 2008
    how to reset router to the factory settings inorder to change the preshared wep key
  • nirmalviswan Aug 29, 2008
    i would like to personalize my siemens gigaset SE568 wireless port with a password
  • yotta00 Sep 01, 2008
    How to open the port of UDP20,000~60,000 and UDP5060, TCP10001?
  • Anonymous Sep 10, 2008
    i want to know about security settings
  • Anonymous Sep 16, 2008
    My siemens gigaset se568 keeps resetting
  • xxSxxAxxMxx Nov 26, 2008
    I am trying to Wifi connect my HTC mobile phone (Mobile OS: windows mobile 6.1) to Siemens Gigaset SE568 WLAN dsl, but its not working.
    my phone can detects and connects to Gigaset SE568 providing WEP key but no internet connection.
    Gigaset SE568 WiFi works good with my laptop.
    my mobile phone workds good with other WiFi access point (in my office and other places).
    can someone please advice what I can do to make my HTC mobile phone work with Siemens Gigaset SE568 WLAN dsl. I guess the issue is with some device settings, it has to be configured right.
  • fidhasiraj20 Dec 08, 2008
    HOW CAN I MAKE MY CONNECTION SECURED?
  • VACHPALIA Apr 13, 2009
    I have a sony erricson P990i phone, i am able to connec to the modem, but not able to browse or surf on internet.
    Can someone give a solution please
  • VeeKayGee May 22, 2009
    Hi, My siemens gigaset se568 is not allowing a software that I use to register; the IT guy says that the router has some firewall which is blocking it. How do I get the router to allow the software to register?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5451
Points
I have a little problem with my siemens gigaset SE568, here all led lights are glowing except the internet, i checked my net connection with another modem and the result was positive but what is the problem here i can't figure out,please help me,rahat
Anonymous
Level 1:
New Friend:
  • Posted on Sep 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5451
Points
Can someone please send the driver to [email protected]
A
Anonymous
How to check the IP Address.
A
Anonymous
To reset this router, there is a reset button at the back of the unit, use any metal or pin with the small tip push the button for at least 10 seconds while the router power on, pull the pin and check the router if all LED lights on, you will successfully reset your router.
If your router keep resetting, this is due to unstable dsl signal, contact your service provider to check this problem, maybe there is a problem with the port termination.
About security setting, you can set security key at any options by entering 10 digits number, goto network options and click wireless setup wizard, enter the SSID or router name, click next unit security option appear and select enable then input shared number at least 10 digits and click finish.
Anonymous
Level 1:
  • Posted on Nov 21, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
5451
Points
2 Related Answers
Anonymous
  • 8 Answers
  • Posted on May 04, 2009
SOURCE: Reseting the admin password on siemen gigaset modem
Usually at the back of the modem has an inside button (it has the tag "reset") that u can push it with the help of a object that has a point. (e.g pencil).
Anonymous
  • 838 Answers
  • Posted on Nov 05, 2009
SOURCE: by which ip using i can open the config page of
First connect the router to your PC, click Start menu button on taskbar click run type cmd now type ipconfig, see the Default Gateway address, open your browser, and type the same address...now the admin page will open....For further help please be with us.Thanks for using Fixya...
1helpful
Hi iam looking siemens.gigaset.se568.driver
Please check the below link you can download the drivers for
gigaset.se568
http://www.bioticaindia.com/gigaset-se568.html
THANKS....
With Regards......
Vaishu
1helpful
By which ip using i can open the config page of
I was using my siemens gigaset se568 in dubai and am now trying to use it with another ISP in india. i have forgotten my security password. is there a way to reset this.
1. Connect your modem with bsnl line.
2. Connect modem to your computer/laptop using LAN wire
3. Power ON your modem
4. Open Internet explorer
5. Type 192.168.254.254 in address bar and click on enter button
6. enter user name as admin and password also as admin. If it not accepts, then reset your router by pressing reset button available in the bottom in hole. Press for 30 seconds
7. after log-in click on ISP Connections.
8. Click on advanced settings
9. Click on Configure the ATM Virtual Circuit
10. Delete the existing entries
11. Click on Add a new VC
12. Enter VPI=0 to VCI=35
13. Select protocol as PPPoE
14. Select the PPPoE Configuration as 'with PPPoE Bridge'
15. Click next button utill page comes for user name password, enter your login details
16. Click on Finish button
17. Reboot router.
That's it, You are done
5helpful
2answers
Wireless LAN not active
loptop not connect to router as wireless
1helpful
I have lost connection with my wireless
I have gigaset siemens SE568 modem i call siemens company to get password so
that nobody can access into my wireless the problem now i can't access to the internet through
my lap-top i tried so many times i put the same security passphrase but no use now i don't want
to enable password i want to disable it cause i need to use the internet though my lap-top
as wireless please help me
6helpful
4answers
Siemens gigaset se587 wlan dsl wpa
You can try this link, this has a step by step instruction and screen shots as well. I hope this one helps.
http://portforward.com/english/routers/wireless/Siemens/Gigaset-SE587/wireless.htm
Top Siemens Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
