B200 error means "Print head Temperature exceeded". In your to solve your problem you need to perform a printer reset. Click Here to view the Canon reset guide or you can follow the steps below:
1) Hold the On/Off button for 1 sec. until the printer shuts off.
2) Unplug the USB cable and then the power cord.
3) Press the power button for 1 sec.
4) Wait 10 minutes, then plug the power cord back in and then the USB cable.
5) Press the power button to turn it on again.
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
4 Ways to Fix Canon Printer Error B200:-
1. Turn off the printer. Wait until the cartridge carrier returns on the side.
2. Turn on the printer.
3. Remove the cartridges. Check the nozzles and clean them if there's any clogged or dried ink.
4. Reinstall the cartridges.
If the problem continues, check this blog or call Canon Printer support services or a Printer Error Support to stop more printer damage the number is in this blog- Canon Printer Error B200
If Canon printer Error B200 is not resolved, this might mean there's waste within the printer's inside. Call the customer services our check this site for a full solution.
Canon printer mp540 ineens doet die niks meer,na herhalen van diverse resetten geeft die b200 aan maar verder niks
Daarna vietnamese tekens op de display maar nog geen teken van leven.
Zijn hele bestaan misschien 100 copies gemaakt en na voorzien van nieuwe cartridges defect.
Wie heeft er een oplossing voor,ik denk zelf vernieuwen en een ander kopen,maar geen canon meer,
SOURCE: Error Code
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
SOURCE: how to fix error b200 on my canon pixma mp620
Replace your printerhead will do the trick. Had the same issue with my MP980
SOURCE: Canon Printer iP4300 Error B200 How to fix
All my search, b200 error indicates a dead print head.
