I have been having a trouble faxing lately. It shows the red alarm? I unpluged the fax and checked for a jam. Is there anything else I can check?
Thanks, Kevin
Dear
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Thanks.
hi i have problem with my brother prinetr MFC-8460N IT SHOWS DOCUMENT JAM ALSO MESSAGE ON SCREN CLEAR THE SCANNER JAM THEN PRESS THE STOP KEY STATUS SHOWS RED LIGHT WE ARE NOT USING SCANNER WE ONLY USE FAX AND COPY RIGHT NOW BLUE LIGHT IS ON FAX AND WHEN I PRESS COPY BUTTON IS NOT ALLOWING ME PLEASE ADVISE
alarm flasing can be more than one thing. check to see if alarm is representing a symbol on fax machine. It can be jammed paper inside, or toner/ ink run out.
when trying to copy or receive a fax machine will flash printer error and send out blank page i replaced the ink cartridge and blue air tho it but nothing seems to help
The alarm sounds for only 5 seconds.When you receive a fax and the paper jams, the fax will be received into memory. When it has finished receiving the fax, the alarm will sound momentarily. When you remove the jammed paper, the fax will print automatically.
This means your rollers are either dirty or damaged. The same thing happened to my Lexmark printer and they told me to clean the rollers. Nothing happened it still was messed up so they just sent me a new one...
