Question about Coby Televison & Video
Our Coby 524DVD player has been workig fine, but now it will not read the discs. We get a msg that says, "Wrong Disc". Any ideas?
    New Friend:
    Problem Solver:
  • 13 Answers
This might be caused due to dust setting on the lens of the sensor, which  is used to read the disc. You could easily clean the lens by opening up the unit and using a small amount of rubbing alcohol.
Another problem which some users seems to face, is that the spinner which is at the center of the DVD tray, moves down after using the player for a while. This causes the distance between the disc and sensor to change. This might result in erroneous reads. A possible solutions would be to adjust the position of the spinner by moving it up (or down) a bit. Do this temporarily and if it works, use super glue to make sure that the spinner does not move about.
http://forum.ecoustics.com/bbs/messages/15118/152795.html
Posted on Feb 22, 2011
Anonymous
SOURCE:
Coby dvd-514 reads wrong disc
Coby DVD 514 Instruction Manual Page 24
use a dvd player cleaning disc,,make sure the disc is supported,it is NOT a blu ray player,only a dvd player,make sure the discs are clean and not scratched
May 09, 2015 | Coby Televison & Video
2 symptoms; don't know if they're related or not. For some time now, when trying to watch a movie on my small screen Coby Portable DVD player, it will play just fine for about half the movie, then...
I'm sorry that the DVD player is not playing discs are expected. Based on the information you have provided, it appears that the Lens head of the DVD player is dirty. I suggest that you use a lens cleaning disc to clean the lens head and it should resolve the issue.
Thanks for understanding.
Please let me know if the issue persists.
Nov 14, 2011 | Coby Televison & Video
I have an older DVD player. COBY DVD-404. I downloaded pictures from my camera to my computer onto a DVD-R disc and then again onto a DVD+RW disc. Neither disc would play on my player. It comes up on...
Your 'old' DVD player is the problem. It is unable to 'read' picture files. Time to put the COBY away and upgrade to a DVD player that can read .jpg, .jpeg images. Most new players do and they are not that expensive.
Aug 11, 2010 | Computers & Internet
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
No picture
I gave up on the cheap Coby unit and upgraded to a more expensive toshiba one.
Sep 07, 2008 | Coby DVD-224 DVD Player
"another wrong disc"
I too do not understand how to check the motor or change the wire
Jun 29, 2008 | Coby TF-DVD7100 Portable DVD Player
Coby TF-DVD7100 7" portable flat screen...keep getting "Wrong Disc" Error
I have seen this problem on several Yamada & Xoro brand DVD players. If you remove the lid after powering down with the disc tray closed and a disc in it you may well find the ribbon cable to the read head is rubbing on the disc. The ribbon cable is held to the base of the box by a sticky pad under a 45 degree bend in it and a piece of sticky tape !!!. Power up unit, open disk tray, power it down, retape cable to base securely with small strips of duct or gaffer tape (using tweezers helps) and hey presto it will work again. The cable rubbing slows the disk spin speed hence "data read error" unit assumes "bad/faulty/wrong type of disk". All that technology screwed up by using a cheap bit of tape in the factory assembly, amazing eh !.
Mark
Mar 02, 2008 | Coby TF-DVD7100 Portable DVD Player
Wrong disc problem
This is a known problem - there is no fix - if you call coby customer service they will tell you to try a dvd lens cleaner -this will not fix the problem. Best advise - throw it away.
Feb 26, 2008 | Coby DVD-224 DVD Player
Dvd player will not spin disk
Unfortunately, your DVD player is broken. Portable units like these often get bumped and jostled and the motor that spins the DVD quits (very small and fragile). Sorry, I wish there were a magic button.
May 15, 2007 | Coby TFDVD5000 Portable DVD Player
WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Aug 02, 2006 | Coby DVD-224 DVD Player
Televison & Video Logo
7,152 people viewed this question
Top Coby Televison & Video Experts
Ekse
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
