no PC just pavillion stated the case sides sticker HP clearly answer this question, called a service tag
the desktop makes fan sounds, turned on, does it?
2 fans or more, PSU and CPU
monitor tests good , and is not a bad vga cable, proved.
PC (unstated ) bad ok
if PC is bad, and monitor is turned on first
the monitor will show "no signal" or cables not connected or no sync)
(hint, monitor on first, count to 10 turn on PC last)
so test the PC ,oK, it is not hard,.
step 1, do both both fans spin and actually blow air
3 fans or more, with nicer video card with fan.
fan 1 , PSU
fan 2, CPU
fan3, GPU and even case fans exist,
12 steps, #1 is hard power reset.
last of after all is bad motherboard if VGA jack THERE is dead.
i bet it is not a bad mobo, ok.....
if you see 2 VGA jacks on rear of PC or DVI
only one will work, the one on the PCI VGA slot will be active only,so do not use the wrong JACK,]
oK?
I cant see your PC or guess which of vast models made this is, at all.
no monitor stated
no cable types stated,VGA/DVI/HDMI/DP????WHAT/?
NO PC STATED, LIKE PAVILION A6200 SERIES (OLD)
http://pcdied.com/dead-PC.htmlwhy post lacking PC model.?
huge # of models, must be guess and guess wrong?
good luck, finding it , the tests are very easy,ask how.
