Cars & Trucks Logo
Posted on Jul 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lifters rattle when you first crank it up for about 5 mins until warm, Shouldi replace the lifteror wouldbe wasting my money to do so,.It runs great an use no oil 3800 -v-6 in a 2001 camaro, what should i do need help in making the right decisi
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1059
Points
I have a 1997 Chevy Suburban that is ticking and the oil dial reads way low, but then it runs better after warmed up. The oil issue is weird and I know I have to replace the Lifters but how? I am parking daily at a incline would this effect the oil issue?
Marvin
Level 3:
Top Expert:
  • Chevrolet Master 85,242 Answers
  • Posted on Jul 27, 2008
Marvin
Chevrolet Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29059353
Points
266281
Are you sure that the noise is a rattle? lifters make a ticking noise, pistons, piston pins and bearing rattle, lifter tick goes away in seconds, piston and bearing related noises take longer, and in the case of rod bearing not at all, it sounds like you may have piston noise, and in that case I would not worry about it, I would run a few cans of combustion chamber cleaner with you next 2 fill ups, carbon build up on the the # 1 piston ring land can cause the piston to "rock" in the cylinder and make a rattle type noise. I have a 1996 Corvette that has a rattle, it is a piston, GM checked it and told me not to worry about it, of course that advice cost $50.00. Also this type of noise is common to the later production 3.8L V6. Hope this sets your fears of a large repair bill to rest, just drive it, but make sure you use the correct oil and change it when recommended.
1993 ford f150 oil pressue gadge running low after truck warms up
I would put a oil pressure gage on the truck and verify that the pump is good. The lifters should not rattle unless someone has been adjusting the valve lash. At 196000 miles the lifters maybe getting weak, push rods could be wearing.
Lifters 2002 dodge stratus 2.4
I would not waste your money on this noise, it will not affect the operation of the engine and to spend that much to correct a noise on this high mileage of a car is a true waste of your hard earned money. Also I show the lifters to be about $8.00 each. Source rockauto.com
1985 Toyota Corolla, standard 5 speed. Car idles and runs great for first 10 minutes. Once warm, it starts to have engine rattle like piston slap or lifter rattle only at the middle part of the...
Your harmonic ballancer is shot.
With the engine off , key out of the ignition... grasp the belt that goes down to the engine crank and see if you can make it turn a little ... if you can , you will see that the outside of that bottom most pully turns ... while the crank does not...
Replace the harmonic ballancer with a new unit... ( used ones are 90% junk by the time you get em from a bone yard...)
There is a cut out on the passangers side to access the bolt you need to take out... it is behind the tire , so the tire must be removed to access it...
easy fix ya !
Engine on the passenger side makes load clicking sound until it warms up, after it warms up it goes away. It appears to be related to heat expansion. What is that sound or cause?
This could be many sounds. First off it could be the sound of an injector or it could be the sound of the lifters rattling a little until warmed. Usually though the lifter sound comes after the engine has warmed up. Have you had the oil changed at regular intervals? Maybe try some better gas if your not using premium and the car calls for it? Check your owners manuel for this.
3helpful
4answers
MY 2000 Montero Sport has a loud knocking when i Start it UP ESPECIALLY WHEN ITS COLD IT GOES AWAY AFTER IT WARMS UP
Sounds like a hydralic lifter issue. These lifters operate the cylinder valves and run off oil pressure. When the engine is cold and the oil is thick worn lifters tend to rattle. When the engine warms up, everything expands and the lifters stop rattling. There is no easy cure for this except replacing the lifters. Sorry....
2helpful
Ford Focus Rattle
catalytic converter is probably rattling, they do that when they are on the way out, performance will be effected, as it block's, engine cant exhaut properly !
Afer being driven 5-7 miljes my 99 tauras loses
I would have to say your engine is probably shot. The bearings are probably gone. It is possible, i suppose, that your oil pump is faulty. As soon as the oil warms up, and becomes thin, the rods and lifters start to rattle. The same goes for the oil pump, as oil becomes hot, and thin, it may not be pumping properly. I would try a used oil pump, and see if there is any difference before i wrote the engine off.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
