Refrigerators Logo
A
Anonymous Posted on Feb 21, 2011
I have a samsung fridge freezer model SRL 628 EV. It was unplugged to move but when it was plugged back in ( off for only seconds) the alarm sounded and wouldnt go off no matter what buttons I pressed on the control panel . So I turned it off and back on again in order to reset itself as the manual said but the alarm is constant. I left it with alarm on while I went out thinking it might correct itself when I came back, but no luck. Have tried swithching on/off quickly and leaving it overnight but no luck, when swithched back on the alarm sounds. I had to empty the fridge/freezer as it was not refridgerating anymore, interior light doesnt come on, but a few of the lights on the fridge side of temperature bar were lit up and flashed with sound of alarm, when you turn off at the plug the whole control panel lights as if it is going to work but nothing happens. Help. Jayne
Anonymous
Level 1:
Guru:
  • Contributor 683 Answers
  • Posted on Feb 21, 2011
Anonymous
Contributor
Level 1:
Guru:
Answers
683
Questions
Helped
136481
Points
21
Http://www.usersmanualguide.com/samsung/refrigerator__top_freezer/page49
try this page and see if you can find what your looking for. let me know.
1helpful
Hi how do I reset the panel where it is flashing alarm EC on my russle hobbs fridge
To reset the panel on your Russell Hobbs fridge, unplug the fridge from the power outlet and leave it unplugged for at least 10 minutes. Then plug it back in and the panel should reset itself. If the panel still displays the EC alarm, you may need to contact a qualified service technician for further assistance.
Model phsc39eess1. What causes repetitive power fail alarm?
Check the temperture and make the freezer and fridge in the middle setting...wait 24 hours and see if that helps.
My daewoo fridge model FR-402KS is stop working because of high voltage of electric power, but when the door open the fridge lights is working.
If you have high voltage alarm, that will not stop light from coming on. Would make sure alarm is correct. First unplug fridge for 30 seconds then plug back in this should reset alarm If alarm stays off you should be OK if alarm comes back on have someone to check with voltmeter to make sure voltage is high. If not you probably need control board.
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Viking Pro VCBB36 -warming up + alarm
Over the past several years my heat alarm would come on, first time I called a PROFESSIONALLY, he told me to unplug for 24HOURS, than start it. The solution worked for two years, just happened again, unplugged it for 24 hours, and it seems fine. My guess it must need to defrost. Good luck!
2answers
My Samsung refrigerator will not cool
Call Samsung. I had the same problem when Best Buy delivered mine. The delivery people left the fridge in demo mode. The people at Samsung will talk you through it, it is very simple. The fridge should work fine then.
1helpful
Maytag ice20
When replaceing the highvoltage control board be careful to not handle it too much as nano voltages can burn it. Unplug before repair. Simply hook it up the way you unhooked it very easy and in the left back of the fridge. Now that it's installed plug fridge in and push back to wall. Look at model tag and write down your code something like 0304 most likely. Go to digital control hold down door alarm and freezer - minus button for 3sec. then let off door alarm now you should see PE flashing the fridge wants personality code (the one you have wrote down). Let off minus now it should show 0000 now push minus once more a decimal should show up 0.000 the decimal indicates what number your about to change. Move the decimal with freezer plus button and lower or higher number setting with fridge side buttons.Once your done hold down freezer minus till the numbers are flashing then open any door and close. Now the fridge should be working properly.Hope I helped
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
