SOURCE: have a problem in tally 7.2
Dear Archana,
If you are using tally legal. Please check whether the date & time are correct. If correct then check the data folder file permission (readonly, hidden, system attributes) are removed. If not while starting tally press Ctrl + Alt + R for and select company which one is getting error. It will rewrites the data of that particular company. Then close tally and open again check it. If this doesn't work u should contact tally support with u r licence key and product id.
Thanks & Regards
Nanda Kishore
SOURCE: i got error when try to connect tally 7.2 from mswindow 98
Exiting Tally.. Internal Error Contact Tally Solution. Memory Access violation c0000005
SOURCE: Exiting TALLY internal ERROR contact tally solution software ...
how to solve this error please give me solution step by step.
SOURCE: EXITING TALLY!! Internal Error. Contact Tally
My tally 5.4 not open when to try open tally when see exiting tally! file not found. Please give the solution immediately
SOURCE: Exiting tally internal error.contact tally software exception
Exiting tally
software exception c0000005
(memory access violation)
