SOURCE: removing open port
Have you tried a full hard reset? This is done by pressing on the small recessed button at the rear of the unit. Of course all settings would revert back to factory defaults. Perhaps it may be to your advantage to notedown certain informatin such as your WAN IP configurations, security key etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: Port forwarding on dlink adsl2 router
Step 1. Before you open ports in your router, set the computer (or the device) which requires
ports to be opened for, with a static IP address. You can choose any IP address from the
range of addresses you are using on your local network, as soon as it is not used by any other
device. The default range is from 10.1.1.2 to 10.1.1.254. In our example we are using
10.1.1.99.
Windows XP: Control Panel > Network Connections > Local Area Connection > Properties >
Internet protocol TCP/IP > Properties
Windows Vista: Control Panel > Network and Internet > [Network and Sharing Centre] > View
Network Status and Tasks > View Status > Properties > Internet Protocol v4 > Properties
Select the “Use the following IP address” option:
IP address: 10.1.1.99
Subnet mask: 255.0.0.0
Default Gateway: 10.1.1.1 (your router’s address)
DNS: 10.1.1.1 and 61.88.88.88 (or whichever your provider is using)
Now open the necessary ports in your router and redirect the traffic to the 10.1.1.99 address.
Here are the steps:
How to open ports in your router Page 2 of 6
Step 2. Open your web browser and enter the IP address of the router (http://10.1.1.1). Enter
user name and password (default username “admin” and password is “admin”).
Step 3. Click on Advanced at the top and then click on LAN Clients.
How to open ports in your router Page 3 of 6
Step 4. You will need to add a LAN Client (the address of your computer or a device) into the
router before you can open any ports. Type in the IP address of the Computer/Device (the
one you assigned in Step 1). You can specify the name of this workstation under Host Name
(optional). Click Add and then Apply.
Step 5. Go to Advanced > Virtual Server (Port Forwarding). There is a list of pre-set ports in
the router which you can choose from.
How to open ports in your router Page 4 of 6
Step 5a. If your specific application is not listed there, you can add the necessary ports
yourself. Select the “User” Category and click on Add button below.
Step 5b. Enter a name for this entry under Rule Name. Then select the necessary protocol. If
there is a range of ports to open, specify the starting port under Port Start and the ending port
under Port End. If you need to open just one port, specify this port number in all fields
including the Port Map. Click Apply.
How to open ports in your router Page 5 of 6
Step 6. Go back to Advanced > Virtual Server. Under LAN IP select your LAN Client (which
you added in Step 4). Select the Category and the desired Rule or select “User” Category
and you should see the rule which you have created in Step 5b. Select it and then click on
Add > to move it into the Applied Rules section. Click Apply.
Step 7. To save the new settings into the router's memory go to Tools > System. Click on
Save and Reboot button. The router will save the settings and restart.
SOURCE: we have aa dlink DIR615 router. Can you tell me
This button is used to quickly set up wireless networks with the WiFi Protected Setup.
Wi-Fi Protected Setup is used to easily add devices to a network using a PIN or button press. Devices must support Wi-Fi Protected Setup in order to be configured by this method
more information is available in your manual and this forum
If this helped you then please help me and vote kindly, thank you.
SOURCE: my Dlink WBR1310 from dropping my internet connection?
Thank you jamesruss582 you are theonly reply I've gotten. Well I sometimes have my laptop only 2 feet away from the router na the furthest is mabe 40 feet. When I'm connected to the Internet any distence is fine with strongest signal.
But my connection never lasts more then an hour or so and I have to reset the router whaich is hard wired to my desttop. I t really drives me up a wall when I'm working on a project that takes more time. I bought Cisco Network Magic in the hopes it would ddo it but all it is, is another way of resetting the router with a lot of pretty screens, but the siruation is the same. Before I added the D-link router my internet connection never timed out, so I figured it had to be with the D-link. And it happens if I leave the desktop on or shut it down. It is very frustrating!
Thanks again, Rick
I suspect that you have port forwarding rule (virtual server) on port 443 (https) on your router. Try to remove rule or just reset router to factory settings. I have the same router and this problem did not happen. You can also install Router Commander program to boost up router performance.
