You can select the desired ringer patterns of the base unit and cordless handsets. 4 patterns are available for each line. Your phone comes from the factory set to pattern 1. Programming must be carried out separately for the base unit and cordless handset(s). Make sure that the base unit/cordless handset is in the standby mode. Base Unit Handset 4 Enter the desired pattern using the dialing buttons ((1) to (4)) for each line. To move to another line, press H or I. • Each time you select a pattern, it rings. 5 Press (ENTER). • A beep sounds. • To return to the standby mode, press (EXIT). 1 Press (FUNCTION). 2 Press or until the arrow points to "Ringer setting", and press H. 3 Press or until the arrow points to "Ringer pattern", and press H. • The current settings are displayed. Ringer pattern L1 L2 L3 L4
1 1 1 1
