SOURCE: Getting into a Starmate ST2R
The cases are not made to enter, they have an interlocking plastic housing that isn't suppose to release once closed. The unit can be forced apart at the seam but it will damage the housing,
SOURCE: Are starmate 2 radios able to be wireless
as long as the used one is not actually a refurbished on.e The original ST2 has a stronger modualtor, so transmits very well. This modulator has since been ruled in violation of FCC regs, but unless there is an FCC cop, you should still be ok.
SOURCE: my sirus radio displays
I had the same problem. If your radio is a kit and not factory installed in your vehicle it could be the magnetic antenna on top of your car. I had mine for about two years and from moving the radio around, or docking and undocking it, the wire from the antenna broke. It was not cut all the way through but it was enough to cause it to loose the signal. Check your antenna where it plugs into the back of the unit.
SOURCE: my sirius starmate st2r wont completely start. It
Your board needs to be reflowed. Just pop the front cover off, remove the assembly from the back and heat it up (non-LCD side) until you see the solder melt (it will turn shiny). Let it cool for 5 minutes afterwards. You can use a heat gun (set to 1000 degrees F) that can be purchased at a hardware store.
This has a 50% success rate. The problem may also be caused by an internal fault, like a blown fuse or faulty component.
SOURCE: My sirius starmate says "antenna not detected".
The antenna that needs to be replace!
http://satelliteradiofix.com
