SOURCE: dewalt dc 988 cordless drill
posible motor problem, the built in magnetic ring in the motor may broken inside or just to much dust in it. advice when replacing motor also replace th switch for the cost $132.00 plus tax canadian. thanx
SOURCE: model cd55 Ryobi cordless drill driver
Your drill probably has a bad or stripped drive gear. Does the drill operate in forward w/a battery that is not fully charged but yet good.?
SOURCE: ryobi cordless drill
sounds very much like the batterys we used to have ryobi drills but the batterys dont last now we use makita/dewalt/bosch
SOURCE: Very little juice in freshly charged batteries
have you tried the batterys in any other tool?
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
SOURCE: Ryobi impact drill compatibility with normal drill bits
Round bits are not compatible with the Ryobi impact drivers. You need the hex shank "quick connect" bits and accessories. There is an adapter available. it is basically a regular style of keyless drill chuck with the quick connect hex shank that should fit right in to your Impact.
