2 dvds in built-in player
I have come across this a few times, one in fact last week!! The back needs to be removed from the back and the dvd section removed, Dont be afraid this is quite easy to do. lie the tv down face first and remove the stand and all screws, then remove the DVD section, should be 5 x screws and some leads that just clip off.
Then you will need a small screwdriver or a knife to prize the second dvd out, this may scratch your dvd but its better than your dvd player being broke!
Once out place the dvd player back in the set then re-screw it plug the leads back in and turn the set on and try to eject the first dvd, this should now be ok.
Once done, turn the tv off and replace the back on.
Just take your time and Obviously make sure the tv is not plugged in when removing the DVD.
Hope this helps
