SanDisk Sansa Clip MP3 Player Logo
A
Anonymous Posted on Feb 20, 2011
My computer says that my Sansa clip battery is running low but my sansa clip says it has over half of its batteries left.... From [email protected]
dwai1967
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Feb 20, 2011
dwai1967
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
3684
Points
69
SanDisk Sansa C240 1 GB MP3 Player only shows half empty battery picture on screen and wont turn on. So it needs fixing.
Question edited for a lot more clarity.
Question moved from Misc to model category.
Replace the internal Li-Po battery, but try a reset first.
https://www.google.com/search?q=sandisk+sansa+c240+battery+replacement
If your Sansa player is freezing, not charging or not turning on, the first thing to try is a reset of the unit. This will normally clear any temporary condition that may cause the player to freeze or not shut off completely, it's a bit like when your PC crashes and you need to re-start it to clear the error.
Dec 28, 2020
My Sansa MP3 player has stopped working or charging
Sansa Clip Won't Charge - iFixit
iFixit https://www.ifixit.com > Answers > View > Sansa+Clip...
Feb 15, 2021 - I found an older Sansa Clip which will power on when connected to a USB charger or to the computer, but it won't boot up or hold a charge.
1 answer · 1 vote: Hi, Sounds as though the battery has failed and needs to be replaced. I couldn't find a battery replacement guide for a Sansa Clip but here's a video ...
How to replace dead battery in Sansa Clip mp3 player?
Oct 1, 2010
Why is my clip say tranferring and not charging
Jan 16, 2017
Where can I find a new battery? - Sansa Clip Plus
Mar 27, 2017
My MP3 player won't turn on once I remove the charger.
Aug 3, 2015
More results from www.ifixit.com
Sansa Clip Battery is not charging - SanDisk Forums
sandisk.com https://forums.sandisk.com > sansa-clip-battery-is-not-...
Jun 4, 2008 - You can try to charge the device first, to make troubleshooting easier. Unplug the device, then select Settings, then USB Mode, then MSC. Now ...
SANSA CLIP ZIP NOT TURNING ON, NOT CHARGING
Feb 27, 2013
Sansa clip won't charge - SanDisk Forums
Jan 4, 2010
SanDisk Sansa Clip+ doesn't charge, doesn't turns on or ...
Nov 2, 2016
Sansa Clip Zip battery won't charge, goes straight to song ...
Nov 28, 2014
More results from forums.sandisk.com
3helpful
2answers
Should I let the battery on my SanDisk Clip MP3 player run out completely before recharging for longer battery life? I've heard different answers. Some say it doesn't make a difference; others say...
It does not make any difference with these lithium batteries.
In the older Nickle cadium batteries, it does. It gets a memory effect, if you charge them from a half charges state.
My sansa 4gb clip is not recognised by my computer. The computer will not acknowlege the usb either... My sansa has run out of battery. What can I do????
Hai, i have sansa clip 2gb with the same problem. one ultimate answer i got is Sansa clip uses Media Transfer Protocol(MTP). Sandisk(maker of salsa clip) know about the problem which cannot be solved(the earlier sansa products are to be avoided). There is no solution with the company.
2answers
My Sansa clip mp3 player doesn't get detected
Trying:
1. Update Windows Media Player 11 for computer
2. Get in Device Manager, right click on icon device and anable it.
Good luck
Sansa clip won't charge fully
If you have a phone charger with the same connector, plug in you Clip and leave it overnight. This will fully charge the battery. There is not enough power from the USB port.
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
1helpful
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
