A
Anonymous Posted on Feb 20, 2011
My printer canon mp258 show error 6000, how can I solve it?
Anonymous
Level 2:
Scholar:
  • Expert 95 Answers
  • Posted on Feb 20, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
95
Questions
0
Helped
50303
Points
287
You will need to reset your printer and this printer requires a software resetter fo many of its error codes. The newest and best available resetter with full instructions is available here.
Just follow the easy instructions and download their service tool and this should reset any error codes or problems you are having with the printer.
Hope this solves your issue.
Anwar
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 19, 2018
Anwar
Contributor
Level 1:
Answers
Questions
0
Helped
3669
Points
My printer is Canon MP258 error number 6000 how can solove it
7helpful
2answers
Reset canon pixma mp258
Reset Canon MP258 error 5B00 or P07
Indications
When the printer is turned on will show an error MP258 P07 in LCD panels and monitor screen will pop up an error 5B00.
Resetter Canon MP258
1. The printer must be in SERVICE MODE, the way
2. MP258 printer is turned off and plugged the power cord.
3. Press the STOP / RESET and hold, then press and hold the POWER button.
4. The power button is pressed, release the button STOP / RESET, then press the STOP / RESET two times, then release both buttons simultaneously.
5. MP258 printer will process (rather long), then the LCD Panel will show the number zero (0)
6. The computer will detect NEW DEVICE, Ignore it .....
7. This situation indicates the printer is on and ready to reset SERVICE MODE.
8. Download ServiceTool_V1074 for MP258
9. Extract file ServiceTool_V1074
10. Prepare 2 paper in the printer (this is to print at the time the reset process)
11. Run the program ServiceTool_V1074
12. Click the "MAIN", then the printer will proceed, then MP258 will print one page with the words "D = 000.0"
13. Click " EEPROM Clear ".
14. Then click "EEPROM", and the printer will print the results MP258 Re-setter.
"TPAGE(TTL=00000 COPY=00000)"
15. Turn off the printer by pressing the POWER button or unplug the power cable
16. Turn on the printer, and the printer ready to use
I hope this information helps. Thank you for using FixYa!
53helpful
8answers
Error Code E05 Canon MP258
Error Code E05 Canon MP258 may solve by the following steps.
1. Press Stop/Reset button for 5 seconds.2. After five seconds release the button.3. Now your printer will start its process and it is ready to use... thanks
14helpful
6answers
How to fix error P10 on canon mp258
series MP258 printer. According to my experience of Error P10 can be solved by replacing one or more of the following spare parts:
  • Cartridge PG810 or CL811 (can be both).
  • Carriage unit complete with its head cable.
  • Logic Board.
1helpful
How to fix error P10on canon mp258
Canon PIXMA mp258 is a series 3 in 1 printer (print, scan, and copy) in lieu of MP145 and mp198. MP258 printer cartridge uses PG810 series (black) and CL811 (color) so different from the series MP145 and mp198.
It had been several times we found the damage Error P10 (on display) for the series MP258 printer. According to our experience of Error P10 can be solved by replacing one or more of the following spare parts:
  • Logic Board.
Check that easiest of starts before the last of the cartridge until the logic board
2helpful
2answers
Can u help me how to fix canon printing model is mp258 , error number is 6000, what is problem? thanks
Hi cinlytan,
With the error that you're getting with your Canon mp258 , error number 6000 this means that your printer needs to be reset. You will need a software resetter for this specific printer. You may also use the software resetter for its many other errors. Kindly click on this link for the instruction and for you to be able to download the service tool. This should fix the error code that you're getting and other issues with your printer.
Hope it helps.
Thank you for using Fixya.
1helpful
2answers
Printer canon mp258 scane problem error code 2,140,2 give me solution
  • kishor kumbharePrinter canon mp258 scane problem error code 2,140,2
    May 05, 2013
    May 05, 2013
My canon mp258 issue one problem screen displayed error6 can i solve this problem.pls send me a rply
check these two link and see your error code
http://pcmediks.blogspot.com/2010/10/canon-pixma-mp258-error-code.html
http://pcmediks.blogspot.com/2010/11/canon-pixma-error-codes-and-solution.html
My canon printer MP558 show error code 2,155,2 when I use scan function, how can I fixed it?
Mine is MP258 having same problem. I solved when i unplug all the other device using my laptop USB port and only plug in the scanner USB cable and problem solved
Error 6000 is shown!!!!!!!
whenever it try to copy scan or print by canon pixmamp150 printer it shows error 5?please give me a solution to solve this problem.pleeeeeeeeeez
ayman refaie
[email protected]
old marine
old marine
ZJ Limited
ZJ Limited
