Also i would recommend a filter system dedicated to the heater tank itself.
After 18 years there will be a build up . you could flush the tank and see what comes out, replace the line to the sink and dishwasher , then you can decide if you want to replace the tank .Which sounds like it will need to be done .
SOURCE: water build up in dishwasher- clogged drain
I would not recomment putting chemicals in the dishwasher. There is usually some kind of filter in the bottomt at you can easily take out and clean. It's common to have parts of labels and plastic clog this up.
Try removing and cleaning this first. It may also be reached from a separate hatch in the fronc of your dishwasher, depending on the make and model. Just make sure it's securly back in place before you start it afterwards, or you may flood your kitchen.
You may also try to disconnect the hose and blow through it to see if you may be able to blow back any objects stuck there.
If none of this helps your problem may be in the pump, and then it's usually a job for professionals.
SOURCE: need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
SOURCE: I have a 3 year old Sanivite 3 macerator that has
if the unit is properly clean and you have checked the fuse - then i suggest it is the microswitch that needs replacing. these tend to go (break) within 5 years on the sanivite 3 models. If not the swich then it could be the capacitor (try this first - although as the swich is located next to the capacitor you can test this for operation at the same time). if none of this works then its time for a new unit.
SOURCE: My wife and I are
Hi. Your landlord is correct. Anode rod can produce rotten-egg smell. Ask him if he can replace the "sacrificial" anode rod with "Power" anode rod or zinc/aluminum rod to get rid of the smell. However, you need to decide whether you tolerate the bad smell produced by anode rod or the minimal toxin produced by zinc/aluminum rod.
You can also try to drain/clean the tank first then add peroxide treatment and see if the smell goes away. If you do this method, the smell is more likely to come back if you go on vacation and left the heater unused for several days.
This article explains it better: Why Does My Water Smell Like Rotten Eggs (scroll down to page 2)
Let me know if you need further assistance. Thanks.
SOURCE: WHAT SIZE SOCKET NEEDED TO REMOVE ANODE ROD?
Hello EDAN I believe it is 1 1/16" socket.I had 1/2" drive & extention bar as it very TIGHT & hard to turn the rod nut.
