can you please help? I trying to trace a blockage fault in my dishwasher. I have followed all the filter and drain pipe inspections where I've not found any blockage material. I want to remove the side panel of the machine so I can inspect further where the drain pipe connects to the pump. However I'm not able to determine how the side panel is removed. Can you please advise? I'm suspecting that the top needs to be removed to get access to retaining screws under there, but Im unable to get the top off.
Thank You.
I am having the same water draining issue. E14 or E18 almost every time I put the machine on. Let me know if you had any luck!
I have now managed to remove the side panel. The removal of the top was needed before the side could be dealt with. The top remaval is shown in the instructions for the unit. Two ligs at the rear need to be pressed in using a screw driver. The top then will slide to the rear and lifts off. This procedure is for the Siemens model SE25T850GB08 however I suspect that the model this case is attached to would be the same. I've now resolved my issue in this case. I still however have not been able to resolve the water draining problem.
