I had an old windows os, and the Print Master 16 (2004) was workingt properly. Now, I upgraded my OS to windows 7, and the Print Master 16, does not work. Is there any solution?
JG
For the past few upgrade cycles I have upgraded by purchasing the best value new computers with the OS installed. I connect the old computers to the new via a home network. The newest has Win-7 and is much faster, however, the learning curve is steep getting all the old stuff to work. So for some stuff I still rely on the older machine. This has given me the best results.I still use Vista and XP, but if you feel compelled to upgrade do to security reason I would follow the following outline.
Back up on an external USB drive all important documents. You must do this if not Murphy's rules will apply and it can be a train wreck!!
Down load Acronis from Western Digital website. Make a Boot disk.
Create a clone copy of your master C:/ drive on an external USB drive.
Purchase a same or larger internal PC master C: drive "It must be a Western Digital for the free version of Acronis to work"
Replace current drive with new.
Using Acronis boot disk boot up and connect USB drive
Clone new drive from USB with vista OS using the Acronis boot disk and confirm all is well
You now have a way to go back. Your original drive still has the Vista OS with all your Junk and the new drive should have the same.
Using the new drive go to the Microsoft website and go for OS seven. Keep your clone copy of the vista OS on the USB drive in case the seven blows-up during install.
Retain the original C: drive with the vista OS in case you get into difficulty with the new drive.(mark the drive with date etc)
I have successfully done this for computers and keep a drive loaded with a known good OS for the day it all goes bad.
Sync-toy is the backup program that I use to keep everything up to date.
I have checked the specs of your PC notebook, I can see that you can upgrade the OS of your notebook to windows 7, because your PC passed the requirements for the windows 7 OS.
I have checked the specs of your PC notebook, and I can see that you can upgrade the OS to windows 7. Because the specs of your Notebook is suitable for the requirements for Windows 7.
If I understand you correctly you had a previous operating system installed on one hard drive and you just now installed Windows 7 but on a separate drive? When you boot the machine if gives you two boot options, the old OS and the NEW OS?
What your going to have to do is format the drive(erase) that contains the old operating system. Format as NTFS.
Try unplugging the old drive, making sure the new drive is set to master and not slave. Boot up the computer. When you boot up your computer you should immediately get options. One of these options should say "press delete for bios" or press "f6 for settings" You need to go into the bios and make sure the drive with Windows 7 is set to your primary drive in the boot order(hard drive should be first in boot list). We want the computer to boot to the new drive first.
Once you get into Windows you can use a program like partition magic to format the old drive to use as just storage space. You can even use "diskpart' which is an old windows command line utility.
If you reinsert the Windows Disk when you are booting up you will get some recovery options, and if I recall correctly one of these should let you format hard drive space. So, you may be able to do it from there.
Where exactly does the error come up in the boot process? Are you able to boot into safe mode? It may be easier for you to just reinstall Windows 7. If you boot the computer with the disk in the drive, and the BIOS set to boot first to the disk, then during the installation configuration you should be able to have Windows just format the old drive to use as space and install the MBR on the new drive.
Print Shop Pro Publisher version 11 was built for Platform OS: Windows 98 / Me / 95. It is an old software which is not for Windows 7(x86 or x64) OS. This is due to software compatibility issues with Windows 7 ie an old software running on a newer OS Platform.
You have to get a newer version which is compatible with Win 7.
uninstall the printer, and go to HP.com, download the install program for your printer and OS, and follow install directions exactly, do not plug and play.
