Refer to the directions that came with the printer. You will probably need to know your IP address, subnet mask and gateway or if this is set up as a wireless network the SSID (network name) and WEP (password) to connect.
Usually you can just plug in the network cable and it will set itself up using DHCP.
Print the network
settings page to identify if your printer is connected to your wireless
network:
1. Press Setup on
the printer operator panel.
2. Press the right or left arrow button until Network
Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now
print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address.
SSID should be the name of your wireless network. Otherwise, you may need to
reset the printer's wireless network settings.
How to
reset network settings:
1. Press Setup.
3. Press the right or left
arrow button until Reset Network Adapter Defaults is
4. Press the right or left arrow button to display Yes,
pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark
Wireless Setup Assistant on your Mac.
