Once you put the desired temperature, select a cook time and it should solve the heating issue. Atleast that what worked on mine.
Mine sometimes heats up fast as we hear a lot gas sound and other times it takes for ever to reach temp.We have a model mgr5729. Today my wife had to go from 350 70 425 and it took 30 minutes
maytag advanced cooking system oven does not preheat to correct temperature and fails to reach the correct temperature
Mine does the same thing.
I have the same problem and it seems to be getting worse- having to cancel and reselect the temperature only to find it reading 225 instead of the 375 like it is suppose to be.
I would set the temperature and the oven would not heat up. Found that the element was burned out. When changing the element, turn off the breaker as on leg of the element has power on it even with the oven off.
I suppose I have the same problem. During preheat the burner "lites" for about 5-10 seconds and goes back out. It continues this and never reaches temp.
It takes 20-30 minutes to reach the desired oven temperature.
