SOURCE: Scanner
are you pressing ok on the printer? all of your scanning should be done via the MP460 navigator. check your applications under the Canon Utlitiy and click on the MP460 Navigator button. scanning needs to be done via that - not the actual printer. refer to the dialogue box when you are on the MP460 navigator. lower left area has a Save bar, when you click on it tow options: save to PC or save as PDF.
SOURCE: Scanner
Try scanning from the image software you are using, not from the front panel buttons. Go to the TWAIN options and make sure your scanner is selected, then go to Acquire and the scanner software will start. Scan from there without using the scanner front panel.
SOURCE: I am trying to scan photos onto the computer
How is it connected? Via usb? Have you tried powering the printer and pc off and back on? Try to print something, go into your print que and make sure that there are no errors. If using usb, try another port if you have one. Also check your ink levels. HP AIO wont work with low ink levels.
SOURCE: Trying to scan. The Dell All in One center
For normal scanning you can choose the option of Scanners and Cameras wizard in control panel. But it is better if you have software disk of printer because it contains more option.
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
SOURCE: how do i scan a photo - I am pressing the scan
you need to install the scanner software from the canon software disk
Testimonial: "response was spot on and very timely - I feel very obtuse now! "
Scan to an application
You can scan originals placed on the glass directly from the control panel.
1. Load the original face down on the right front corner of the glass.
User Guide 59
Use the scan features
2. In the Scan area, press Scan To.
The Scan To menu appears. The Scan To menu lists destinations, including
applications, for anything you scan. The default destination is the one you
selected the last time you used this menu.
The Scan To menu can be configured. You can designate which applications and
other destinations appear on the Scan To menu by using the HP Image Zone
software on your computer.
3. To select an application to receive the scan, press until the destination you
want appears on the control panel display, and then press Start Scan.
A preview image of the scan appears in the HP Scan window on the computer,
where you can edit it.
For more information about editing a preview image, see the onscreen HP Image
Zone Help that came with your software.
4. Make any edits to the preview image in the HP Scan window. When you have
finished, click Accept.
For more information on editing a scan in the HP Scan window, see the onscreen
HP Image Zone Help.
The HP All-in-One sends the scan to the selected application. For example, if you
chose the HP Image Zone, it automatically opens and displays the image.
If you don't have the HP solution center, you can download it from this link:
http://www.hp.com/global/us/en/consumer/digital_photography/free/software/photo-creations.html
If you found this answer helpful, please remember to leave positive feedback.
Were you able to do "scan to computer" before without any problem? It could be just a slight communication problem. Unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When your printer turns on completely, replug it into your computer. Doing this usually fixes minor communication issues. Hope this helps.
