Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My copier, Image Class MF 6590, makes the copy but the roller does not work and the paper gets jammed.
pl2323
Level 2:
New Friend:
  • Expert 89 Answers
  • Posted on Feb 18, 2011
pl2323
Expert
Level 2:
New Friend:
Answers
89
Questions
0
Helped
30161
Points
160
Try using 80 grade papers instead of 70 grade papers. Problem might go away.
2answers
Paper gets folded and jams as the paper gets pulled into the machine from the paper tray below in my image class MFN
clean the roller's with some rubbing alcohol and the paper should go straight, UNless something got stuck in there, Ripped piece of paper might also be the cause, the older the unit the more it needs the rollers cleaned,
Paper tray in my image class MF8350 won't close
There's probably a piece of paper wadded up in the feed mechanism. Carefully remove the paper tray and look in the feed rollers. Also be sure all the "guides" are in their proper orientation.
I own a Canon Image Class MF 4550 d. This morning
Try turning the printer off and back on. If this does not work, try rebooting your computer. Another choice is to go to the Control Panel > Programs > Unistall a Program and delete the printer's software, reboot your computer and re-install the printer's softwre.
If this does not work, you can always return your printer for a full refund or ask them to exchange it for a new one.
Tengo una image class mf 6540 marca error E000 NOSE COMO QUITARLO
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermister. Hope this helps...please post back for further assistance.
Daniel
D1120 IMAGE CLASS CONTINUOUS PAPER JAMS ALTHOUGH NO PAER ACTUALLY JAMMED. APPEARS THAT PAPPER IN PAPER TRAY IS NOT FEEDING OR CATCHING UP TO BE COPIED.
first of all try to clean trays picked up rollers and also look for a piece op paper or something else in internal paper path
pifonski
My canon image class 6590 jams everytime it trys to copy or scan from the feeder above or on top of the machine
you may have worn out rollers. bad sensor or a whole punch stuck on the sensor. you need a tech to repair ir.
1helpful
Canon image runner 7105/7095/7086
try cleaning your pick up rollers but sounds like they need replacing, just clean them with window cleaner and rag
Canon Copier MF 6530 stopped printing after a paper jam, everthing else works fine no error code just won't print. I have remove the cartridge shook it and still nothing. Do you have any suggestions?...
I would reset the Photo conductor unit. It will have a Green drum in it. I would make sure it is set in the machine all the way, and that the drum door opens completly. BLANK copies are and indication the paper has NOT touched the drum to recieve an image.
1helpful
2answers
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
old marine
old marine
ZJ Limited
ZJ Limited
