Kool! Questions without answers. I'm off to buy a new one. I am sure that solution will satisfy the corporation that will not sell replacement parts!!!
You can't post conmments that contain an email address.
If your Koolatron cooler is not cooling down, even though the fan is working, there may be a problem with the compressor or the refrigerant.
The compressor is a critical component of the cooling system, as it is responsible for compressing and circulating the refrigerant that absorbs heat from the air inside the cooler. If the compressor is faulty or damaged, it may not be able to compress the refrigerant properly, resulting in poor cooling performance.
The refrigerant is a chemical substance that absorbs heat from the air inside the cooler and carries it to the compressor, where it is compressed and released. If the refrigerant level is low, the cooler may not be able to absorb enough heat to cool the air effectively.
To fix this problem, you will need to diagnose and repair the faulty component. This may require the assistance of a qualified repair technician, as repairing a cooler's cooling system can be complex and hazardous.
PDF
replacement parts, please telephone the following numbers ... CVF18-G. Please Read These Instructions Carefully Before Use! S.V.P., lire ... For long periods of storage, a small container of baking soda or charcoal, placed inside, will eliminate.
Hiya Mike
Solution 1 - Dont lend cooler :)
(just kidding)
Not familiar with it but would be very surprised if the plugs are interchangeable. I should be power in and the other for the thermos. Check and see visually and if they can be mixed up and dont get a response, could try sending a pic of the PC and see if go any further.
Best of luck. Ganx
One of our scientists has just asked me to take a look at his Koolatron (which he is using as a field incubator), it seems he is having similar problems to yours. I expect to have it apart tomorrow so will post a wiring diagram after I have
