Purchased a Vestax typhoon new, using with a Macbook. Installed Traktor LE, it's operational using my keyboard (when set to internal mixer). No driver installation because of Macbook, it recognized Typhoon driver automatically. but when set to external mixing mode. Typhoon controller is powered, and audio is routed out contoller through monitors, but nothing works on the controller, except for output volume (jogs, volume, crossfader, anything) -no headphone monitoring -is a signal, just static
tried turning off comp with everything plugged in, switching USB.
Try replacing the fuse by one with same voltage and rating. Usually if you take a look at paperwork that came with the mixer it will show you which fuse you should use.
Make sure the Windows computer has the audio output selected to use the computers output hardware.
In the control panel, under "sounds and devices" pane, VOICE tab, that the Voice playback window shows your COMPUTER's audio system AND then check the volume is turned up by clicking the Volume button right under that same window. Now do the same under the AUDIO tab at the sounds and devices pane.
Make sure you have loaded the right driver for this and the operating system is allowed. Vista and later sometimes won't work unless you have compatible drivers.
and download the .tks file for your version of Traktor. Suggest you save it to the Traktor program directory.
Then within Traktor in the controller settings section, load the .tks file, save and you're good to go. Obviously you can tweak the configuration as much as you like once it's loaded. Suggest you always keep a backup of the original.
