Samsung SyncMaster 730MW 17" Flat Panel LCD Monitor Logo
A
Anonymous Posted on Feb 17, 2011
My syncmaster 730MW used to take some mins before coming on..then it got to an hour, now it gone of completely what do i do?
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Feb 17, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557496
Points
31058
> what do I do ?
Spend $50 to $100 at any TV/video repair-shop, for trouble-shooting and repair.
Or, spend $40 to $50 to buy a used 17-inch LCD screen, or $100 to buy a new 19-inch LCD screen.
1helpful
My sony big screne started shutting itself off and wouldnt come back on for several hours. Then it would power up and standby flash 7 times and after a few mins the picture would be gone but the sound...
On your tv you have cooling fans on the back side you will need to check to make sure that they are running. Lay your tv on the bed take off back cover (it's not hard) and used some air-in-the- can to remove dust from the back! If you need a fan go to Partstore.com (1-866-925-PART
1helpful
Power problem
The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
Take care.
Phone has gone completely dead. Only 3 days in use from new.
Your best bet is take it straight back and get a replacement or refund.
If you want to try and fix this it can be done at the dealers ,try a new battery
or try a different charger.
There`s one more thing for not being able to turn the phone on.
Try charging the phone until it has stopped charging.Connect the charger and charge for 2.5 hours.The battery icon might not appear until the phone has charged for 30 mins.
Hope it helps
My Syncmaster 730mw keeps losing its picture afer a few seconds. No matter which input I use VGA, SCART, Component the picture comes up crystal clear and then flicks off after about 1 - 2 seconds! I can...
If you can make out a faint image then the fault is a backlight problem.
The fault could be an inverter board or the CCFL lamp/s
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site : -
www.lcdparts.net
The screen will not come on
i think lose power
i hope i can solve your problem
All touch Keys locked?
I had the same problem. Hold the menu button in for 5-10 seconds and it will unlock.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
