Probably close to 50 things could cause that, but here are a few of the most common: Bare wire in a harness of the oven, causing a short-circuit in the line. Faulty plug on the power cord. Outlet in the wall is damaged. Loose wire in the outlet box, causing a dead short. Bad wire between the outlet box and the main breaker box. Weak breaker, or a breaker that isn't heavy enough to handle the load of the oven. (especially, if you just bought a new oven, it may need a larger breaker to handle start up.) Use a fused multi-meter (voltmeter) to check for these issues, and do not try to fix it if you are not familiar with electrical work. It could cause a fire, or give you a deadly shock.
I had similar issue with my electric stove as well. The model of the stove is the same as the one that us mentioned above on the beginning of the this discussion. The issue I had on my stove was that the display shows time and no error code how ever the oven top light indicator comes on but the oven won't heat up. Here are the steps I took to fix the issue: First I unplugged the stove and used a multimeter to verify that it has 240Volt coming. It checked good for 240v. Second, I opened up the terminal on the stove where the plug connects, there I discovered one of the hot leg has melted and broken thus only 120v getting to the stove. I repaired the broken wire and verified 240v coming in the stove and stove was fixed for good. I further investigated what caused the wire to melt and broken, my finding was exposed hot wire shorted to the stove body (ground). Hope this helps. Thanks for reading
If you are not knowledgable in electricity, call for service.
This is an electrical short at the light, I have seen this before.
The wiring for the light has grounded to the oven. This causes the main fuse to blow. You will need to fix the short first. Then reset the main fuse/replace.
In the case of the wall oven, you may have to remove the oven to fix it properly. Depending on the model and where the short is.
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
After letting the stove cool, I pulled the entire unit out from the wall and discovered scorch marks on the wall. Opening the back panel revealed a simple fix: the "element on" light module had shorted and was visibly scorched and melted. Looks like a simple replacement (and some wire stripping where the leads fused). Stove currently works with the affected wires capped off (while I await a replacement module).
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
