Follow the steps to transfer pics from your computer to your iPad:
Step 1: Connect your iPad to your computer using the USB data cable that came with your iPad.
Download Install and run iTunes and select your iPad device from left panel under "Devices" section.
Step 2: Click on Photos tab, Check the "Sync Photos from" checkbox and select "Choose Folder..." option from drop-down menu. Locate the folder with the photos you want to transfer on your computer and hit "Select Folder" button.
Step 3: When folder listed in iTunes, select all pictures that you want to copy to your iPad and hit Sync/Apply button from bottom right corner.
I recommend you a professional software, which can help you transfer pics from computer to iPad. Then you can enjoy the files on your iPad freely. iPad to PC Transfer is a professional sofeware, which can help you transfer Music, Movie, Photo, ePub, PDF, Audiobook, Podcast and TV Show from iPad to PC or iTunes library.
Do you want to transfer pics for computer to ipad. ?? you can do it with ipad backup software. you can transfer all format of pics such as png, jpg, gif to your ipad. you can also backup ipad with this tool.
To transfer pics from computer to iPad:
1. In the iPad management screen, click the
"Photos" tab at the top.
2. Check the "Sync Photos" box at the
top.
3. From the drop-down menu next to that, select
the program or folder that contains your photo library.
4. Once all your settings are correct, click the
"Apply" button at the bottom right corner of the iTunes window to
sync again and add photos to your iPad.
5. Photos will consume space on your iPad, so
keep that in mind as you select between syncing all photos and individual
albums and videos.
http://www.iphone-mac.com/how-to-transfer-files-from-computer-to-ipad.html
Transferring the iPad mini files is now possible with iPad mini file Transfer in best and easy way. so if you also need to transfer files then for more info visit http://www.ipadminitransfer.com website
If you want to transfer your image from computer to iPad in better way and quickly then by using iPad Transfer tool, you can transfer you image as well as audio, video and emails too. for more detail log on to http://backup.ipadtransfer.org
You can also use dropbox for all photos,books,etc.You can also share these photos across all your electronics.Download dropbox to computer,sign up,add photos to photos folder.Download dropbox app on ipad,sign in and all photos will be available.Dropbox.com
Ipad transfer,
It allows you to import video, audio, photo files or folders from iPad to computer, photos from PC to iPad.
I use this, reckon to you.
You can transfer pictures using itunes.
Or you can use a app called photo transfer app here is the link http://itunes.apple.com/us/app/photo-transfer-app/id365152940?mt=8#
