Nokia 7210 Logo
A
Anonymous Posted on Feb 17, 2011
Hi, I Have nokia 7210 supernova phone.From past 5 days it's not working. The Problem is when i switched on mobile it get hanging with the logo nokia.I need the contacts stored in phone memory. Please get me solution. Email Id: [email protected] Mobile: 09916228891 Bangalore,Karnataka,India
Anonymous
Level 3:
President:
  • Master 1,812 Answers
  • Posted on Feb 17, 2011
Anonymous
Master
Level 3:
President:
Answers
1812
Questions
0
Helped
527839
Points
7608
Just follow the steps
Take a full backup.
First Try it:
You may try default phone and security code to remove it
Defalt phones codes is 12345 or 00000 you can use it
if the problem is same do the next,
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If
Soft reset( factory setting)
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
tip
Hi, I Have nokia 7210 supernova phone.From past 5 days it's not working. The...
Do you want FixYa team fix your problem quickly? Many people posted their problems on FixYa without complete idea of problems.Here are some sample ( equivalent) questions posted that need the answers :
1.Laptop problem 2.Hello sir 3.Software 4.Need air conditioner manual.
All of above questions are very broad, not focus, and will generate tons of answers.
Now compare above questions with these :
1.Laptop problem. It cannot detect USB connection on thosiba Satellite L5102.Hello sir. My Toyota Prado 2002 cranks but will not start3.Software. I need software of Canon MP 198 printer for free4.Need air conditioner owner manual of Trane model MCW507K
Again, please post the complete idea of your problem to get fast response and answer.
on Feb 17, 2011 • Cell Phones
Mobil nokia7210 switchoff,it is not on?
just update u r phone and u r phone its on :D jack
Dec 06, 2011 • Nokia 7210
3helpful
2answers
My nokia 7210 supernova phone was not starting it get hanging with the logo nokia.and it is not get connected to pc suite
If your phone could not start up in normal mode,it cannot connect to PC.Besides, hanging with Nokia logo is surely a software.Flashing is the only solution.So, follow this step.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 7210c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment/Click here1. thanks for visiting fixya. Good luck.
Aug 27, 2011 • Nokia 7210
36helpful
6answers
I'm forget my 7210 supernova security password. how can reset this password
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
OR:
Reset factory setting with nokia flasher box.
Thanks
Sep 07, 2010 • Nokia 7210
208helpful
9answers
How to format my nokia 7210 supernova???
MY NOKIA 7210 SUPERNOVA MOBILE IN MUSIC PLAYER "OPERATION FAILED" ERROR
Apr 14, 2010 • Nokia 7210
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
