Efficient Networks SpeedStream 5200 Modem Logo
Posted on Feb 25, 2018
Hi, if i am using rigth now, the Efficient Networks SpeedStream 5200 is support by my DSL operator ( ISP ) internet services provider , can i purchased the SpeedStream 5270 , and will work ? will be compatible ? please and also is the 5270 better or 5200 is better ? thank you
2 Related Answers
Anonymous
  • 8 Answers
  • Posted on Oct 19, 2007
SOURCE: speedstream 5200
here is the pdf download link for this modem
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
should be of some use
Anonymous
  • 124 Answers
  • Posted on Oct 31, 2010
SOURCE: Power requirements for an Efficient
You need a power supply which converts AC to 12Volt DC power.
While purchasing Please keep in Mind that the ADSL power IN socket should be matching with the new Power adapter.
How can I obtain a user guide for Acatel optus one touch 250 P/N16513 corded phone?
Optus Network Approved modem and equipment list
If you are supplying your own DSL modem and/or telephone filters, you must ensure they meet the requirements
below before connecting them to the OptusNet DSL network. Connection of unapproved equipment is prohibited.
The modem list contains equipment that has been certified by manufacturers as having passed interoperability tests
r
equired for use on a DSL network. If your modem make and model isn't listed below,
call Optus Customer Service for further information on
1300 309 333.
F
ully supported by OptusNet DSL Broadband Customer Service, the OptusNet DSL Broadband Installation CD-ROM will automatically
c
onfigure this modem.
D-Link ADSL Modem 302G
The OptusNet DSL Broadband Installation CD-ROM provides detailed information to manually configure these modems, and OptusNet
DSL Broadband Customer Service will provide limited connection support for them.
(Equipment Certification date in brackets)
F
or modems and routers other than those above, OptusNet DSL Broadband provides only the network connection settings needed for
manual configuration. While this equipment can be used on the OptusNet DSL Network, no OptusNet DSL Broadband Customer Service
will be provided for connection configuration or equipment-related connection difficulties.
Alcatel SpeedTouch - 510 ADSL Modem (15.01.2003)
Alcatel SpeedTouch - 530 ADSL Modem (15.01.2003)
Alcatel SpeedTouch Pro - 4 port (10.09.2001)
Alcatel SpeedTouch Pro - Firewall (09.10.2001)
Alcatel SpeedTouch PCNIC (04.08.2000)
Alcatel SpeedTouch USB (04.08.2000)
Askey/Dynalink - ALE 070 (08.01.2001)
Askey/Dynalink - ALH 110 (21.03.2001)
Askey - RTA100 ADSL Modem (25.10.2002)
Billion Electric - BIPAC-711 CE ADSL Modem (25.10.2002)
Cisco WIC - 1ADSL-DG (30.06.2003)
Cisco 827 (19.02.2001)
Cisco 827H (11.07.2002)
Cisco 827-4V (19.02.2001)
Cisco 837 (01.04.2003)
Cisco SOHO77 (29.11.2001)
Cisco SOHO77H (11.07.2002)
Cisco SOHO97 (01.04.2003)
D-Link ADSL Modem - DSL 100D (08.08.2001)
D-Link ADSL Modem - DSL 500 (08.08.2001)
D-Link ADSL Modem - DSL 504 (08.08.2001)
Efficient Networks - C10 Communications - Speedstream 3060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 4060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 5260 (08.01.2001)
Efficient Networks - Siemens - Speedstream 5400 (07.04.2003)
Efficient Networks - C10 Communications - Speedstream 5660 (21.03.2001)
Efficient Networks - C10 Communications - Speedstream 5667 (10.09.2001)
Efficient Networks - C10 Communications - Speedstream 5861 (21.03.2001)
Juni NetAce - ADSL USB Modem (15.01.2003)
Juni NetElite 2000ES - ADSL 4 port Modem (15.01.2003)
Juni/Samsung SAM-215 USB Modem (18.07.2001)
Juni/Samsung SAM-335A Ethernet Modem (18.07.2001)
NetComm ADSL Modem - BusinessSmart (08.08.2001)
NetComm ADSL Modem - USB - NB1200 (27.08.2002)
NetComm ADSL Router Modem - NB1300 (20.11.2002)
Open 501r ADSL Router Modem (05.04.2002)
Alcatel - Central, Part No. 3AU 04804 AAAA
Alcatel - In-Line, Part No. 3AU 04805 ABAA
Askey/Dynalink - In-Line, DT60-002BA
C10 Communications - Dynamic - In-Line, C10290
C10 Communications - In-Line, C10611 & C10611T
C10 Communications - In-Line, C10645 & C10645T
C10 Communications - In-Line, C10610
Te
l
ephone Equipment - Central, TE-ACP20AUS01
C10 Communications - In-Line, C10211
C10 Communications - In-Line, C10111
C10 Communications - In-Line, C10145
C10 Communications - In-Line, C10245
D-Link - Central, DSL-10SP
D-Link - Central, DSL-10CF
D-Link - In-Line, DSL-10MF
Alcatel SpeedTouch Home
D-Link ADSL Modem - DSL 200
D-Link ADSL Modem - DSL 300
D-Link ADSL Modem - DSL 300+
D-Link ADSL Modem - DSL 302G
Optus supplied modem
Optus preferred modems
List of all other certified modems/routers
List of certified filters/splitters
Information correct as at 2 February 2004.
1270049 06/04
Nov 12, 2014 • Cell Phones
Does the speedstream 5200 offer wireless capability?
No it do not ahev wireless feature. details fo this devices are:-
Manufacturer: Efficient Networks Product MPN MPN 33A-5200-701 Key Features Router Functionalities dtrquestion.gif Firewall • DHCP Server Connectivity Wired Interfaces LAN Interfaces 10/100 Base-T WAN Interfaces dtrquestion.gif ATM Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif ATM • DHCP • IP • PPPoA • PPPoE • TCP Routing Protocols RIP Version 1 • RIP Version 2 • Static Routing Remote Management Protocol dtrquestion.gif HTTP • Telnet • SNMP 1 Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • DoS Prevention • NAT Authentication PAP (UPAP) • CHAP Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) • ADSL Full Rate (G.DMT ITU G.992.1) Other Features LED Indicators Power • WAN • Activity • DSL Additional Features Auto Crossover (MDI/MDI-X) Warranty Warranty 1 Year Miscellaneous Release Date 2003
CAN NOT GET CONNECTED TO INTERNET USING 5100. WORKS OK WITH 4100
1: get a firmware update from your internet service provider if does'nt work.. get the modem replaced from ISP
DSL connection (Modem) problem
Contact AT&T DSL support for help in getting your network to work. And do not believe them if they tell you your modem is no good. They want to shut down their DSL service and will go to any length, lying included, to get people to change over to their fiber optic system.
E.F. Speedstream 5871 router
You may be able to use these with "standard" DSL, which generally does require PPPoe (a username and password, basically). But you'd certainly need to have an ISP providing DSL service, the correct wiring drop to the device, and your DSL provider would need to support this particular device on their network.
These are not routers, per se, they are really just DSL modems.
Speedstream 5260
there is a problem with yur dsl connection check for physical setup between the modem and the telephone wall jack
if the problem exists contact your isp
if u r not too sure abt the physical setup pls contact your isp providers and they will help you to run through the steps
5200 speedstream blocks my peer to peer sites, mystic island game site, all bittorrent downloads and limewire
Hi Shepherd1880,
First thing:
The computer that you're using for these services needs to have a static IP address configured in your private network and not a DHCP address assigned by the router.
Secondly thing:
Depending on your security policies (computer firewall and/or router), you will need to sure that the settings from your router and/or your PC firewall are not blocking the ports that you need to connect for these services.
Once you know that you have this area covered, you can move forward with the necessary procedures to properly configure your Speedstream 5200 using the link below:
http://portforward.com/english/routers/port_forwarding/Efficient-Siemens/Speedstream-5200/BitTorrent.htm
Hope this helps!
4answers
Speedstream 5200
Will not connect
First, I would make sure you are using the right type of patch cable to connect to your cable/dsl modem. There are two types: 1) Straight through 2) Cross over The manual for this device says to use #1 when connecting directly to a computer, and #2 when connecting to a hub. http://www.fltg.net/Software/5667B%20Quick%20Start%20Guide.pdf If the cable/dsl modem is powered on and you are not receiving a link light on either the cable/dsl modem or your computer, try using a different cable. If this does not work, then you may have a problem with the device itself. At that point, call your Internet Service Provider, as they may be able to provide you with a replacement. If you did not receive this device from an ISP, then you will have to contact the manufacturer directly. Unfortunately, it looks like Efficient Networks was bought by Siemens, so you may have a hard time receiving support from them. http://www.efficient.com/ http://subscriber.communications.siemens.com/broadband_family_frame.htm
Top Efficient Networks Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
