Yamaha RXV367 Receiver Logo
Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My rx-v367 does not power on, i think the protective circuitry has been activated. How do I reset it?
Electro Med Services
Level 3:
  • Yamaha Master 6,694 Answers
  • Posted on Feb 17, 2011
Yamaha Master
Level 3:
Answers
6694
Questions
Helped
1870119
Points
21433
AV receivers shows protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong. Is there is any standby light. If not check the AC fuse.
Normally AV receivers show this when any of the output amplifier get some problem. there are five amplifiers in this AV receiver. May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
First of all remove all speaker connections from the amplifier and powerup the amplifier. If the amplifier turns ON then, then any of the speaker have some problem.
If not You have to check the amplifier.
for that you need digital multimeter,soledring iron screwdrivers etc
open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
after replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. put the bulb in a holder. now you have to wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim . if so check the display, is there is protect mode is on or not . if not and come back to normal operation ,then remove the power , remove the bulb insert fuse and check
connect the power and check.
If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components.
ok
How do I reset Yamaha rx-a4730 it won't turn on just blinks Manual says it is in circuitry protection mode
Yamaha RX-V650 won't power on - Service manual, repair and unlock ...
forum.eserviceinfo.com/viewtopic.php?t=59945
10 posts - ‎6 authors Posted: Sat Aug 29, 2009 1:26 pm Post subject: Yamaha RX-V650 won't power on ... When i came back from a holliday, my receiver won't power up anymore. .... isn't powered (no voltage on the base) when the receiver doesn't comes on.
RX-V800 shuts off after 7 seconds turned it on, what should I do?
Can you post that diagram here? Or you can email it to me. I can't make any promises, But Im glad to help, I have done much board work in my time, and this one just sounds interesting. L8R
5helpful
How do I reset the protection circuitry on Yamaha RX-A820?
press and hold the 'tone control' and 'info' buttons and press power. This will release the protect. The first thing that show on the display will be the protect code to tell you why it shut down. If it turns right back off, then you most likely have a short in the amp that will need to be repaired.
My rx-v367 turns on then shuts off immediately
YAMAHA RX V367 HTR 3063 SM Service Manual free download schematics eeprom...
bad or leaking capacitors or shorting somewhere first disconnect power amplifier a variable powersupply variac it can be very helpfull
Faulty right speaker
Sounds like a bad speaker. There isn't anything in the receiver that would cause it to not pass certain frequencies.
10helpful
The protection circuitry has been activated 3 times consecutively and as a safety precaution, capability to turn on the power is disabled.
If there is no apparent cause for the protection mode activating (such as shorted speakers, burning smell, blown fuses, lighting strike or mains power surges), reset the protection as follows and see what happens.
Connect power cord to mains and wait 5 seconds or so. While holding down "info" and "tone control" buttons, press "main zone" power button briefly and release, but keep "info" and "tone control" buttons pressed for at least 3 more seconds. The unit should power up. Assuming the reason for the protection has passed or been fixed, the unit can now be turned off and then back on with the "main zone" power button to restore normal operation mode.
If the protector activates again, the fault is still present and the unit needs to be repaired, ideally by a Yamaha authorised repairer.
There are dangerous voltages present in high power amps and a lot of grunt in terms of stored energy - best left to trained technicians.
1helpful
After power outage, the units internal saftey switch has activated. How do i reset the reciever? It's a Yamaha RX A1000
If the protection circuitry has been activated 3 times consecutively you may have to contact Yamaha as it says in the Troubleshooting section of the manual.
http://usa.yamaha.com/products/audio-visual/aventage/rx-a1000_black__u/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Need code for Yamaha RX-V367 for Motorola DRC800 remote. Thanks!
Thank you for your question.
Yamaha RX-V367
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v367_black__u/?mode=model
Motorola DRC800
Here are a few codes to try:
0054
0030
0179
0706
1helpful
2answers
Yamaha Receiver RX-V367. Connected a WII to the audio/video jacks in front. Sound but no audio Do I need to select a certain device from input menu?
I am trying to connect my Wii with the component cables to my yamaha rx-v367. No video but sound. What am I doing wrong?
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
