Vizio P50HDTV10A 50 in. Plasma HDTV Logo
Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Visio 50" Plasma Model#
Anonymous
Level 3:
  • Vizio Master 5,138 Answers
  • Posted on Feb 17, 2011
Anonymous
Vizio Master
Level 3:
Answers
5138
Questions
5
Helped
1004372
Points
13534
Have you removed the back and looked for Bad Capaciotrs on the power supply board?
Capaciotrs will be vented or puffed up on Top. 1000uf 16v,2200uf 10v 3300uf 10v etc....
Ian Dempsey
Level 2:
New Friend:
  • Expert 85 Answers
  • Posted on Dec 04, 2012
Ian Dempsey
Expert
Level 2:
New Friend:
Answers
85
Questions
23
Helped
19106
Points
169
Sounds like bad caps and the click is power relay going to safe mode cap repair kits are available on ebay cheaply
1helpful
Have 2008 vizio smart tv-how do you program a new remote to the tv or tv to the remote?
Hello Mat,
Read the instruction manual that came with the remote as that has codes in it and the procedure to program the remote also. You can also look up the codes via the internet using the make and model of the remote. The listing will usually have all possible codes that might work with your Vizio tv, and you have to try them all until you find the 1 that works.
Good Luck!
Rich Lilja
My VP504fhdtv10a vizio plasma TV when connect power cord the Vizio in front light up yellow/amber but will not turn on
This is a classic switchmode power supply, has sensed a severe potential problem, and is shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done
1helpful
My VP504fhdtv10a vizio plasma TV when connect power cord the Vizio in front light up yellow/amber but will not turn on. I have replace Logic Control D Board still have same problem. I do research online...
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
We recently purchased a Visio lcdhd tv and the manual that came with our Jumbo uiversal remote doesn't show the code setting for the Visio. Is there a code you can give us.
We can't give you the code without specific model numbers for both the TV and remote control. Try the codes for the Visio models that are listed in the manual. There is a good chance that Visio used the same coding system for more than one model. If that doesn't work, check the Internet support page for your remote control. It may have additional models listed, and one may apply if Visio used one of the other remote control systems on the market at the time your remote control was manufactured.
2helpful
My Visio 50" Plasma Model# VP504FHDTV10A was purchased in June of 2008. Recently when I try to turn it on, it makes a click sound and then the Visio emblem turns a dull amber color and the TV will not turn...
I just solved this kind of problem with my VIZIO VP504FHDTV10A. It was main power supply that went bad. You need to open back panel cover and right in the middle you will see two powersupply boards(subpower board(smaller) and big main powersupply board). Just get board part/model # and search it on eBay(what I did). It was approx. $100. Good luck.
1helpful
2answers
Bought a Wii and using the standard cables it played great on a new 50' Panasonic Plasma as well as on our 2 year old 32' VIZIO LCD. Just upgraded to a 46' Sony LCD (W series) and the Wii looks terrible...
The Wii can display on a HDTV, but keep in mind the output is only 480p. It is not true high definition, and it will only display this using a component video cable. There shouldn't be a difference with LCD and plasma.
You will also need to go to the display settings to force the Wii to display in 480p.
Try a different input (safe to assume your Sony has multiple?) and see if it is that specific input. Also, try a different device like a DVD player or VCR and see if you get the same result.
Good luck.
1helpful
Pioneer Elite Plasma TV 2-yrs old loses color randomly.
Would need model number to search properly. On some sets a capacitor "C2601" of Y-Drive assembly contacts the audio bracket and it is damaged, can cause a abnormal picture.
Sound but no picture on 32in visio plasma
this sounds like you need a professional, can you get it fixed under warrenty
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
