It may be necessary for you to change the Video Output Settings on the PS3 in order to see a picture.
Reset Video Output
If you are changing cables or cannot see an image on the screen, you may need to reset the video output to default settings. To reset the video output:
While the PS3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PS3 beeps a second time (approximately 5 seconds), then release it.
The PS3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Manually Change Video Output
If you wish to change the video cable or change the video resolution you may manually change the video output.
In the XMB™ home menu, go to Settings icon(Settings) > [Display Settings] icon and press the X button iconbutton.
Highlight [Video Output Settings] and press the X button iconbutton.
Select the appropriate connector type you are using for your TV (i.e., HDMI, AV Multi, etc.) and press the X button iconbutton.
You may be informed the console will "test the settings for 30 seconds". Press the X button iconbutton to "Change" the display of the system.
If your TV has multiple "Input" or " Video " channels, (i.e., "Input 1", "Input 2", "Input 3", etc.), you may need to toggle through each "Input" channel on your TV to find the correct one that will display the appropriate picture for your connection type (i.e., HDMI) during the 30 seconds, especially if you do not see a picture. The system will remain in the selected connector type for 30 seconds.
Select all resolutions that are supported by your TV (i.e., Standard, 480p, 720p, etc.) and press the X button iconbutton.
Select the TV type (either "16:9" or "4:3") and press the X button iconbutton.
Verify your selections on the final screen and press the X button iconbutton to save your settings.
At this point, you may choose to [Set Audio Output Settings] or to [Finish]. Click here for information on setting the audio output settings.
To view the supported resolutions for each cable visit What determines the video resolution for the PS3?.
Here are some great source where will will get any kinds of Gaming Consoles Solution
» Sony Playstation 3 (PS3) Console
» Microsoft Xbox 360 Console
» Nintendo Wii Console
» Sony PlayStation Portable (PSP) ...
» Nintendo DS Lite Console
» Sony PlayStation 2 (PS2) Console
Number of vote for this solution:7
We would be happy to help get that fixed right away. The first thing we want to ensure is that all connected equipment is on. We want to then check what type of cable was used to connect the TV to the receiver. If you are using a Coax Cable to connect the receiver to TV1, check the receiver's back panel for the output name. If your receiver has a "TV CH 3/4 out": Tune TV to channel 3 or channel 4, back if it is labeled "Home Distribution": Tune TV to channel 62 or 75. If using non-Coax (RCA, Component, or HDMI) to connect receiver to TV1, cycle through the inputs until picture appears; Most TVs have a "TV/Video", "Input", or "Source" button. If we are still not getting a picture then unplug receiver for 10 seconds then plug it back in, this will reset the receiver, then try cycling the inputs again.
We hope these steps resolve the issue. We want to thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
