SOURCE: Printer prints always only a blank page
2 more things to try. Assuming it is USB Change USB port. Re boot the computer. Replace the cable. Reboot the computer. Coming back to the driver software. Go to Start /Printers and Faxes/Install new printer Leave what is there in place When the Wizard comes up and asks CD or Select from list Choose select from list - then go to HP and your model and simply load the generic driver. Try each alteration one at a time Tell us what you get.
SOURCE: DEsignJet 1055CM Plus (Plotter)
It is most likely the network card. Take it out of the plotter(while it is off nad unplugged) and restart it to see if the problem returns
If it does,it is going to be the hard disk..
SOURCE: printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
SOURCE: my hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
SOURCE: HP 1055cm printer drivers do not show up on MAC OS9.1 'chooser'
uninstall the Hp printer driver and software.
install the printer software from the CD. download the driver from HP (driver only).
