You need the code for your stereo; try getting the vol.cdrom for your car.once the battery is removed without the necessary back up this will occur. There is a correct way to replace a battery check the manual.
If anyone opted out to replace battery in their own watch and do not know what type and size of battery is correct for replacement, just open your watch case back and reed and memorize all the writings on battery your watch allready has in it. All you can do now is to buy exactly the same replacement battery and you will never get it wrong. All that matters is the combination of letters and numbers on battery. Make is not important, so, it can be made by Casio, Maxell, Citizen, Ronda - you name it. Just make sure you are not buying some of those cheap, unknown maker batteries, as they usualy lasts for about few weeks and then they are gone. Choose well known makers name and the battery will power your watch for 2-7 years, depending on each particular watch movement model. In case if you lost your original watch battery, check your watch instruction manual. If you lost both - battery and manual - then there is no other way, but to visit your nearest watch repair shop and ask for help.
if you had battery replaced,they may have lost a spring.there is a mute mode. your manual number is on back of watch in a box. use that number to look up the manual in casios website.you can set tone
often removing the batteries in both units will reset. replace batteries in indoor unit firs, let it settle down then insert batteries into outdoor unit. There may be a button on outdoor unit to initialise the connection.
Alternatively you might find the manual here or get the instructions from their support.
According to the manual "the LED Indicator will flash when charging the battery and will be steadily on when the battery is fully charged."
If you would like a copy of the manual, I can sell you one for $8.99 including shipping to lower 48 states. If interested, email me at [email protected].
warm regards,
Marisa
You need to replace the internal Battery with the
Panasonic BR2032-1F2 battery. However, yes your waypoints will most likely get lost when you do this.
