Just a Delphi 12VDC cigarette lighter adapter plug that will plug into this unit. You will also need an XM mini car antenna plugged into it. This has a nice FM transmtter, so you can use that, or use the audio output plug to go to your car AUX input jack or use a cassette adapter. Okay? More questions, just ask.
Are you playing it directly thru your FM antenna connection, or using the RCA jacks? You have to set the FM modulator level. It is also possible that you have a new FM radio with a type of ALC that will raise the lever regardless, but your regular car radio volume control should work. do not wire this directly to a power amp, as you won't have the control that you need. Good luck, let me know more.
No experience with this issue, but in your shoes I would check the satellite antenna connection into the back of the unit. From there, I would chase the wire and make sure it is not frayed. If that does not resolve or lead to a resolution of the issue, borrow an XM antenna and see if it will work then. If not, then something has happened internally with the head unit, most likely at the antenna connection jack.
Unfortunately your tape play has the auto reverse feature. It is detecting that the tape is not turning via a reel counter. Sensing no movement ( as you have an audio adaptor inserted rather than a real tape) it is trying to switch to the other side of the tape.
Not very much you can do.
You could purchase an FM modulator and basically re-transmit the Xm over an un-used frequency on the FM band to slve your problem
Get a cassette to ipod hook up. They are just black cassette tapes with a cord coming out that plugs into your ipods earphone jack. They're usually around $20.00
1. Make sure your SKYFi2 is turned off. Unplug any accessory from SKYFi2’s audio jack. 2. Turn on an FM radio and place it close to your SKYFi2. 3. Tune the FM radio to each of the following FM frequencies: 88.1, 88.3, 88.5, 88.7, 88.9, 106.7, 106.9, 107.1, 107.3, 107.5, 107.7, and 107.9. 4. Note the frequency that has no FM station or the least amount of interference. 5. Turn on your SKYFi2. 6. Press the “menu” button. 7. Use the scroll wheel to select “FM Frequency.” Press the “XM” button to confirm. 8. Use the scroll wheel to select the frequency noted in step 4. Press the “XM” button to confirm. 9. Press the “menu” button to return to the main menu and then again to return to the play screen. 10. You should now hear XM programming over your FM radio. If the sound is not clear or you hear interference or static, try another frequency by repeating the process above.
For the Ilo CA3000v, all you need is an XM direct tuner box, Model XMD1000, the cable that came with the Ilo radio, and an RCA cable to connect the two. The RCA jacks and the 8-pin DIN jack on the back of the ILO CA3000v are exclusively used for XM signal translation.
You will, of course, need a subscription to XM Satellite radio, but the items listed above cover the extent of the hardware you'll require. The XMD1000 comes with the antenna as well, so no need to worry about that, and all XM features are controlled from the head unit itself
