Look at the back of the printer, you will find 2 latches at the back of the printer, you need to press those latches to open the rear access door. once the rear access door is open you can take the paper that is stuck inside the printer.
Press the On/Off button on the printer control panel to turn off your printer.
Wait 30 seconds.
Press the On/Off button to turn on your printer.
If the error continues,
double-check that all paper and foreign objects are removed from inside
your printer. NOTE: Even if you do not physically see a paper jam, you will need to follow the paper jam link to solve the error. Paper Jam Error
Hello, Welcome to FixYa! Error 3528 in Kodak Printer is mostly because of paper jam. their may be small bit paper jam in side. There are some "micro-sensors" that detect a paper
jam. To solve it Try taking off the roller access panel in the back and make sure that the printer has not picked up a sheet of paper somewhere in the path.Also make sure that sure that really there is no piece of paper paper, dust or foreign objects.If you have seen and you are sure that there is no any paper or foreign object then Turn
the printer off, and disconnect the AC power-cable. Open the printer
cover & now give the printer a "blow-job" by compressed air. Turn the printer On and check. If you still face this error then try a trick may be it can resolve the issue. Press the On,Off button on the printer and turn off your printer. Now wait for 30 seconds.Press On button to turn your printer On and try printing. If still there is an error then then probably your Kodak ESP 3 Multifunction Printer/ Copier/ Scanneris in need of servicing by a service professional. I hope this solution helps you. Thank you for using FixYa!
Sounds like there is a sheet of paper jammed in it. Try taking off the roller access panel in the back (not the access panel by the cartridges). Make sure to only use clean sheets with proper humidity level to avoid jams. Also fan the sheets before feeding to disperse any static.
Check the complete paper path very carefully, it only takes a small fragment of paper stuck somewhere to signal a paper jam. Also check that the paper sensors have returned to their normal positions. See that the printer has not picked up a second sheet of paper and this is somewhere in the path.
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper.
The same goes for photo paper too.
