Toshiba Satellite A15-S129 Notebook Logo
Anonymous Posted on Feb 16, 2011
My toshiba a15's cd/dvd rom can't read dvd's anymore. it used to. is it just a setup thing? thanks
  • Anonymous Feb 16, 2011
    Hi Jarrett622. Thanks for the quick update. I forgot to say that it does not recognize a dvd. It's as if there is nothing on the disk tray.
Nanny
Level 3:
Genius:
  • Toshiba Master 2,351 Answers
  • Posted on Jan 02, 2020
Nanny
Toshiba Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
988779
Points
7262
You can download a free DVD player to play the DVD to see if it can't work. If it still won't work, then maybe it is the issue of DVD drive machine or the DVD disc file problem.
jarrett622
Level 2:
Scholar:
  • Expert 74 Answers
  • Posted on Feb 16, 2011
jarrett622
Expert
Level 2:
Scholar:
Answers
74
Questions
Helped
28425
Points
227
The newer dvd's often won't play on older machines. The easiest solution is to download and install the VLC Media Player. The VLC Media Player is an open source free player and can be downloaded here.
Hope this solves the problem.
  • jarrett622
    jarrett622 Feb 16, 2011
    That's exactly the problem I was thinking it was. Try the VLC player. I had a computer in here last week had the same problem. The VLC player did the trick. :-) It's the codecs and the encoding they're using now as opposed to several years ago.
I have a toshiba satellite it will not play any audio sound and when you go on the volume it says it as toshiba dvd-rom sd r2412 and all i want is sound on my laptop can you help me please
Do you have sound at all, or just not when you play a CD or video DVD?
Fist thing to check is if your audio drivers are installed and working properly.
If necessary, find and install the right sound driver for the computer.
There are some more things to try to fix sound in Windows, hope that helps.
Cant read cd/dvd
The problem will be in a lens of the driver of your computer.
Try to clean by any lens cleaner cd and check it
If then also it is not working means contact service person and submit for repair
2answers
DVD Rom
try re-installing the device drivers to sort the problem
1helpful
Toshiba Satellite don't want boot from CD
try doing this.. go to your bios and change the boot sequence and select the dvd/cd as the first boot option.
let me know what happens
2answers
Dvd decoder
YOu need a 3rd pary dvd player software installed, Like power dvd. Power DVD , Win Dvd etx, you should have gotten a copy of a player when you brought your computer, If you didnt or cant find it you can download one, many have trial versions or you can get a free one.
If you get a trial version of Power Dvd it automatically installs a dvd decoder. even if power dvd trial expiers and you cant use it anymore you will still be able to play the dvd's on windows media player cause the decoder will remain there and media player will have axcess to it :)
Dvd-ram
RUN a register cleaner or repair program
I use TUNE UP UTILITIES
Reinstall drivers
DVD/CD-RW drive
you might have to update your dvd driver. Go to my computer and then properties,then disk manager. Look for the DVD driver and then update it...You might also update your windows..Hope this helps...
2answers
Toshiba A30 - DVD-ROM CDRW
Wow, That's a weird malfunction. Only TDK??? What about other media types? Did you try a diffrent burning software?
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
