But basically, you just need the time changed unless you are asking time zone related questions. You realize Alexa is the woman inside the device like Siri is inside an iPhone. Device model details are useful in such questions.
For Windows 10 following these steps to change the time and date:
1. Right click on the time (Normally at the bottom right-most corner of your screen, on your start bar)
2. Select Adjust date/time
3. Press Change (Button under Change date and time text)
4. Set the time/date, and press Change
You can also change your timezone, daylight savings and automatic internet vs manual time on that setting page.
Press the Windows key on your keyboard to display the taskbar if it isn't visible.The Windows key has the Windows logo on it.
Right-click the Date/Time display on the taskbar and then choose Adjust Date/Time from the shortcut menu.
The Date and Time dialog box appears.
Click the Change Date and Time button.
The Date and Time Settings dialog box appears.
Enter a new time in the Time field.
You can also use the up and down arrows next to that field to change the time.
If you wish, click on a new date in the calendar display and then click OK.
You can also change the time zone, if necessary.
Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
If you don't want your computer to adjust for Daylight Saving Time, click Change Time Zone and click the Automatically Adjust Clock for Daylight Saving Time check box to turn this feature off.
Open Date and Time by clicking the Start button , clicking Control Panel, clicking Clock, Language, and Region, and then clicking Date and Time.
Click the Date and Time tab, and then click Change date and time. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
In the Date and Time Settings dialog box, do one or more of the following:
To change the hour, double-click the hour, and then click the arrows to increase or decrease the value.
To change the minutes, double-click the minutes, and then click the arrows to increase or decrease the value.
To change the seconds, double-click the seconds, and then click the arrows to increase or decrease the value.
When you have finished changing the time settings, click OK.
To change the time zone, click Change time zone.
In the Time Zone Settings dialog box, click your current time zone in the drop-down list, and then click OK.
1. Point mouse to time and click > change date and time settings > change date and time > continue > select appropriate time and date > OK > apply > OK > DONE.
2. Go to bios settings change date and time > save settings
To change the time you need a way to change the frequency of the carbon atom which is used to determ time in atomic clocks, the GPS system and by Greenwich Mean Time.
To change to Daylight Savings time, follow instructions for your time zone on the following website.
What do you mean it "does not change"? Have you tried to change them using the Control Panel applet, or by clicking on the time in the taskbar and trying to change it there? Or, do you mean the date and time is not incrementing at all while watching the time?
Here's the solution to your problem: > Tap the "Change preferences" icon > Tap the Arrow Icon until you reach the screen with the "Set Clock" Icon > Tap how you would like the time displayed > Tap done > Set the correct time to display > Tap Done
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
