Sir i locked my keypad with security code other then 12345.
then some one tried 5 times with wrong code.now it is not accepting the actual code.what to do sir.my IMEI no is-353105/02/196386/3
Switch off the Nokia 1200 phone. Remove the battery for 30 minutes.Reinsert the battery and switch on the Nokia 1200 phone.Enter the default code 12345 or 00000.Your Nokia 1200 phone will be unlocked.
You can set up a security code to lock your Nokia 6288 keypad in case a thief tries to call from your stolen phone
Published on Mar 14, 2007
You can set up a security code to lock your Nokia 6280's keypad in case your phone opens in your pocket and calls one of your contacts, annoying them and potentially running up a huge bill.
The code will also stop a thief from using your stolen Nokia 6280 to run up a huge phone bill before you can alert your network provider.
To set the security code, click Menu > Settings > Phone > Security keyguard. You'll be prompted for the Security code. By default this is 12345. Enter this and press OK. Select On and click Select to see the message 'Security keyguard activated'.
Now when you slide your phone shut and press Lock, you'll see the message 'Keypad locked with security code'.
When you slide it open, you'll be prompted to enter the security code. Type your code and click OK to activate your keypad.
Of course, if any potential phone thieves are reading this, they'll now know the default security code is 12345.
To change the security code, go to Menu > Settings > Security > Access codes > Change security code. When prompted, enter your current security code and click OK. The enter your new security code (a PIN between 5 and 10 digits in length), click OK and enter the new code again to verify it. Click OK and you'll see the message 'Security code changed'. Hope this helps.
Your Nokia Master Code: 3617311310
this is master code.. it has to be entered when your phone is started and asks for code..(security or master)..
if you type 5 times wrongly,the phone will get whole locked.. so,try 1 time and let me know about this..
if you fully typed 5 times wrongly ,you have to get a lead and software tools to unlock and that costs greater than the phone you got..
so,try 1 time and let me know..my email id:[email protected]
Default security code is 12345. You have already tried it once, and phone still requests a security code, please bring it to your Nokia
service center.
Some operators configure phones so that they only work with their brands'
SIM cards. In this case, if you enter the wrong code three or more consecutive
times, the phone may lock permanently. If this happens, contact your operator or
service provider for assistance.
In other cases when you enter the wrong code three or more consecutive
times, the phone switches to a "sleep mode" and does not accept any entries for
the next 15 minutes. In this case, power the phone off, then back on, let it sit
idle or untouched for 15 minutes, then try again or bring it to a Nokia Care
point.
