You most likely accidentally positioned it off screen as the recycle bin cannot be deleted. What you need to do is right click on the blank desktop and click "arrange icons". This will re-sort all of your icons (including the recycle bin) and your recycle bin should reappear. If you (or someone else) has gone into the system settings and removed the recycle bin from the desktop, then you'll have to follow the following procedure:
Right click on the desktop
Choose Personalize
In the personalize window, look on the left column and you'll see Change desktop icons.
Click on Change desktop icons
Make sure a checkmark is placed beside the Recycle Bin
Click OK
Right click on your desktop and select and select 'Personalize'. In the window that comes up on the left hand side under tasks select, 'change desktop icons'. This will launch yet another window. In this final window make sure there is a checkmark in the box for Recycle Bin. If there is a check, un-check and recheck it. Click apply at the bottom of the page and that should fix it.
Here's how to get it back. Right click on the desktop then click Personalize, once there click on the top of left pane on Change Desktop Icons. Here you can choose which icons you want to appear on the desktop, just tick next to Recycle Bin and click OK.
Click start all programs navigate to the HP Pavillion Slimline right click on it click send to desktop to create short cut
hope this helps
