1.
Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace
keypad (also called touch pad or membrane switch). Some models incorporate
keypad in to control board as one unit. In this case, replace control board
(also called ERC or clock).
http://www.appliancepartspros.com
F2 - E1
Keypad cable unplugged
E1 F2 is a "Keypad Tail Disconnected" error. This actually means the keypad has failed and cannot be detected by the control board (unless it has been unplugged from the control board). These may be obsolete from the OEM, however there is a solution for you here:
Introducing the Ledgestone Technologies Touchpad
Models: GBS307PDB0 GBS307PDB1 GBS307PDQ0 GBS307PDQ1 GBS307PDS1 GBS307PDT1 GBS307PDB11 GBS307PDB12 GBS307PDB3 GBS307PDB4 GBS307PDB5 GBS307PDB6 GBS307PDB7 GBS307PDB8 GBS307PDB9 GBS307PDQ11 GBS307PDQ12 GBS307PDQ4 GBS307PDQ5 GBS307PDQ6 GBS307PDQ7 GBS307PDQ8 GBS307PDQ9 GBS307PDS11 GBS307PDS12 GBS307PDS3 GBS307PDS3 GBS307PDS4 GBS307PDS5 GBS307PDS6 GBS307PDS7 GBS307PDS8 GBS307PDS9 GBS307PDT11 GBS307PDT12 GBS307PDT3 GBS307PDT4 GBS307PDT5 GBS307PDT6 GBS307PDT7 GBS307PDT8 GBS307PDT9
Hi
F2-E1 Error indicates
a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the door
appears to be closing fine then it is the control board that is bad and should
be replaced. Hope this helps...please post back for further assistance.
Daniel
