Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Amazon.com, Inc.
Rating: 3.8 - 30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Panasonic Projection TV Lamp Timer Resetr
Pull off the panel below the screen.
Remove the two screws hold the 2nd cover from the left.
Remove one screw from the lamp module and pull it out.
Buy the lamp module. It is not worth it to try replacing the lamp. You can damage the bulb easily.
