Question about Epson Stylus Pro 9800 InkJet Printer
Please, I want to know error code no. 00010014 EPSON Stylus Pro 9800.
  • 2,361 Answers
00010014 - Ink System Pressurization Error (The Pressure Sensor does not indicate pressure) CClick HERE to view full detail on troubleshooting process.
EXPLANATION:
The error codes in the table below relate to a faulty ink cartridge or detection of the cartridge when installed in the printer. These errors only occur when an ink cartridge is changed. Whilst you may be unable to quickly identify which ink cartridge may be at fault, the steps below provide a process of elimination.
    Posted on Feb 15, 2011
    Service call error 10004
    SERVICE CALL 00010014
    Description
    Failure of pressurizing
    Jun 27, 2012 | Epson Stylus Pro 9800 InkJet Printer
    Erreur 00010014 for my epson 9880
    The 00010014 error code indicates that the Ink System Pressure Sensor reports low pressure.
    This error usually is caused by an Ink Cartridge that leaks pressure.
    Try to replace the cartridges, look in your manual, there should be more information about this error and how to fix it.
    Jul 06, 2011 | Epson Stylus Pro 9800 InkJet Printer
    Please, I want to know error code 00010014 of EPSON Stylus Pro 9800 InkJet Printer
    The error code is a service request.
    The machine requires a service
    Feb 15, 2011 | Office Equipment & Supplies
    Message is Service call error 00010014
    Description
    Nov 21, 2009 | Epson Stylus Pro 9800 InkJet Printer
    Epson 9450 Sercvice call error 00010014
    The problem is with the ink cartridge. remove the ink cartridge then insert it again... if this does not work, replace you ink cartridge. hope this help. Good day!
    Jul 07, 2009 | Epson Stylus Pro 9800 InkJet Printer
    We are getting error code - 00010014
    The same has happened to me I replaced one of the inks and got the error message 0010014. I replaced the ink cartridge with another and it began working again or maybe this link might help you.http://www.epson.co.uk/Printers-and-All-In-Ones/Large-Format/Epson-Stylus-Pro-7800/Drivers-Support?target=article&extn=.html&articleId=4286
    Good luck!!
    Apr 09, 2009 | Epson Stylus Pro 7800 InkJet Printer
    EPSON STYLUS PRO 10000
    00010014 Pressurization error
    Ink supply pressure incorrect
    Explanation
    The pressure system is determined to be leaking then this message appears and printer is stopped when detection of pressure origin sensor is incorrect at power on initialization or ink supply.
    Solution
    1. Replace supply pump assembly (including pressure origin sensor solenoid).
    2. Check for disconnected air tube.
    Aug 30, 2008 | Epson Stylus Pro 10600 InkJet Printer
    Epson service call error message 00010014 Call customer Service and Support Call 1 8O5*465*751O Toll Free 24x7
    thanks for rating
    Jan 09, 2008 | Epson Stylus Pro 9800 InkJet Printer
    Epson Stylus Pro 9800 InkJet Printer Logo
    499 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Thomas F. Schneider
    Ekse
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
