Remove the toner and the paper tray and open every door on the printer. Take a can of air and blow out every nook and cranny in the printer. Check and carefully wipe all rollers. There a fuser kit in the printer, likely in the back. If you feel comfortable with it, remove the fuser kit and use a can of air to continue cleaning. Reassemble the printer and run a few test pages, it may look like a bigger mess for the first few pages (up to 25). However, as you run the pages the print should clear up. If you still have a streaks on the pages, you will likely need to order an maintenance kit from dell. This kit should include the fuse, rollers and other replacement parts for the printer.
I hope this has helped you
