SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader Logo
Posted on Feb 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My San Disk micro SDHC Memory Cards 8GB wont format and when put in a device it heats up. What is wrong with it?
Anonymous
Level 2:
  • Expert 92 Answers
  • Posted on May 21, 2011
Anonymous
Expert
Level 2:
Answers
92
Questions
0
Helped
18613
Points
198
Technically, some card readers dont have any regulators to minimize the voltage to read a microSD.. some direct card reader can destroy/ damage your memory card.. try to use an all-in-one card reader, or a microSD adaptor then put it in your card reader slot..
Card reader slot in laptops made for memory cards only.. =))
4helpful
2answers
I've tried formatting a new san disk 4gb card and still reads "unable to use card" what do i do?
You haven't told us what kind of camera it is, but I can guess at the problem. There are two possibilities.
1. Your camera will only read SD cards, not SDHC cards. You've just bought a new memory card, not noticing that it was SDHC. The new cards don't work in your camera, not because they or the camera are broken, but because they're not compatible.
Cards up to 2Gb are generally SD. Cards over 8Gb have to be SDHC. 4Gb cards can be either SD or SDHC, but are almost always SDHC because they're cheaper. (I would avoid the rare, expensive, and problematic 4Gb SD cards.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. (If it does, it probably means that they made a 4Gb card, but there were some error locations and so they disabled half of it and packaged it as a cheap-brand 2Gb.)
2. You formatted the card NTFS, whereas the camera needs FAT32. You can format the card using Windows, but there is a complication: Windows defaults to "NTFS" when formatting, but memory cards normally use FAT32. Before you attempted this, you should have connect the card, and checked the 'properties' on the drive that appears. It probably said "FAT32". In this case, you could have gone ahead and formatted the card, but be sure that you chose "FAT32" from the drop-down list. If you format it NTFS, your camera won't be able to read it!
In this case your solution would be to format the card again, but using the FAT32 format.
You might find it useful to check your camera on dpreview (dot) com, and see if the memory card type is shown as just SD or SD/SDHC.
Jan 20, 2011 • Cameras
5helpful
2answers
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
10helpful
I just purchased a sandisk sdhc card 8gb memory card.how do i my camera says it is the wrong format.press ok and it will format it....i pressed the ok button and it says unable to format.can you help.
The problem is that you're using an incompatible memory card.
Your camera is designed to use SD memory cards up to a maximum 2GB capacity. Click on this link for the user manual and look at the specification on page 43 under the heading "storage".
You're trying to use an 8GB SDHC: not only is the capacity far too large for your camera to handle, but it's a later technical standard which your camera does not have the hardware for. SD and SDHC cards may look the same, but are very different "under the skin". SDHC compliant devices are backwards compatible with earlier SD cards, but SD devices like your camera cannot be updated to use SDHC cards.
Your only fix is to replace the SDHC card with an SD card of no greater than 2GB capacity.
Please take a moment to rate my answer.
I CANT FORMAT IT IM USING WINDOWS I HAVE AN 8 GB SANDISK SDHC CARD ND IM TRYING TO ADD MUSIC TO IT ... IT SAYS THERE IS 0 MB LEFT ON THE CARD ITS BRAND NEW !!!
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format card
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
2answers
My imate-jam cant recorgnise my memory card it is a kingston 8 gb but it can recorgnise a memory card of 2 gb (san disk)
Hello kenac, this may seem like a simple thing, but sometimes the simple things are the last ones we think of. Do you have any data on the 8GB card, if not, you can reformat it in the device and it should be happy. If the device does not have an option to format the card, you can format it in any computer that has a slot for it.
Hope this helps.
-Chris
1helpful
My new 8gb sandisk says it is not formatted and I can't format it
well i heard on another website - that because the memory card can hold alot of memory, the computer doesnt accept it, so you need to use a usb memory card reader, ebay sells it for like £1
Formatting troubles for a 8gb Sandisk Micro SDHC
Hi Tony,
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
Rob
Meory card wont read
go into phone status then storage devices then pick the memory card and hit options and you will find format there
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
