SOURCE: Where to purchase Stabilizer Bars for Delta Luv Crib #4750-6?
What is wrong with the stabilizer bars that came with the crib? If they broke or fell apart, you should report that to the CPSC as it could be a safety issue.
SOURCE: Was the Delta Luv Duchess crib- model number
You can look up the recall list for Delta cribs at the cpsc.gov website. You can call Products America at 800-205-9642 or 800-772-1041. We offer a wide verity of hardware and instructions for many cribs.
SOURCE: Is Delta Luv Crib 4980 built 12/3/03 on recall
Hello Shohola107,
I found this recall list. I did see your model listed. Here is the list.
Delta cribs manufactured in Taiwan or Indonesia, with the “Crib Trigger Lock with Safety Peg” drop side hardware design, numbers:
4320, 4340, 4500, 4520, 4530, 4532, 4540, 4542, 4550, 4551, 4580, 4600, 4620, 4624 (production dates 01/06 thru 11/07), 4640, 4660, 4720, 4735, 4742, 4750 (production dates 01/95 thru 12/00), 4760 4770, 4780, 4790, 4820, 4840, 4850, 4860, 4880, 4890, 4892, 4900, 4910, 4920, 4925-2, 4925-6, 4930, 4940, 4943, 4944, 4947, 4948, 4949, 4950, 4958, 4963, 4968, 4969, 4980.
Delta drop side cribs manufactured in China through 2005, with the “Crib Trigger Lock with Spring Peg” drop side hardware design, numbers:
4340, 4343, 4520, 4600, 4620, 4624, 4625, 4629, 4660, 4665, 4720, 4750, 4751, 4850, 4855, 4857, 4880, 4920, 4925-2, 4925-2B, 4925-6, 4980, and 8605.
You can also check out this website. http://www.deltacribrecall.com/recalled_products.asp
Thank you
SOURCE: Is there a crib recall for the Delta Luv Crib,
Yes, please follow the link below for the replacement part order form.
http://www.cribrecallcenter.com/cinfo.asp?recall=2&co=1&m=4750-1&p=90002
If this information was helpful, please take a moment to provide a "thumbs up" rating. Thank you!
