Try pressing the following key pad buttons within 5 seconds - PREWASH OPTIONS - WASH TIME, PREWASH OPTIONS - WASH TIME, in this sequence and allow the washer to run. The LED display will start counting down as the washer begins a sequence of short diagnostics tests. If no error is present, the washer will return to standby. If the error persists, you may have a blockage in your drain pump. Please run the test and let me know the results. Total test time is about 1 minute 40 seconds. I hope this helps you.
whirlpool calypso clothes washer stuck on the "FL" for overfill code - will not reset after hitting stop/cancel or after unpluging - one year ago the customer service for whirlpool gave us the code for a series of buttons to push to cnacel the "FL" alarm and continue with a normal wash cycle - the washer is not overfull it just lost sequence during a wash cycle
awesome - thanks for the quick response jsrock516 - i knew there were codes avaiable that were a sequence of buttons to push but whirlpool customer service would not tell them to me and they are not in the manual and they would not transfer me to a tech who could help - this is like built in obselesence? so that someone has to pay an outrageous service call fee - unfortunately i am unable to test your suggestion because i fixed the problem by siphoning out the water and playing with the cycles until the machine reset itself - thanks very much for the info - i will keep it for furhter use
Whirlpool GHW9100LW will stop during drain cycle and code F02 will flush. If the cycle is cancell and power is disconect to reset, then it will drain when cycle is resume. What will be the cause, is it the main control board that cause this, deffenitely not the pump
