This could be anything from a Vacuum Leak, Idle Control Motor failure, Throttle Position Sensor failure, O2 sensor failure, Fuel Pump failure, Fuel Pressure Regulator failure, Fuel Injector failure, Bad Catalytic Converter, etc. What color is the smoke coming out of the tail pipe? If it is white, it could be a cracked head or blown gasket.
Here are some common solutions to your symptoms:
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
You have water in gas your going to have to drop gas tank and clean or you can try gas cleaner maybe that will fix the problem.
